- Thank you received: 225
This could potentially suck
- Old Man Rock
I'm not so sure about this statement, maybe I'm miss understanding (most likely).
Reasoning, the cam degreeing (valve opening/closing) and setup is to TDC.
The Dyna S is also static time based on TDC for ideal and desired combustion ignitions.
The crank rotation is controlling your camshaft/lobe valve operations via the timing chain...
All in all, these all work in harmony/unison and must be set accordingly or no worky for optimum performances.
Oh well, no biggy, hope it works out well for you big man!
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2098
Ignition timing. The spark plug fires when the crankshaft gets to a certain position during its rotation. The spark plug doesn't know what the valves are doing.
Cam timing. Determines when the valves open and close during crankshaft rotation. The valves don't know what the spark plug is doing.
Good Luck!
- keith1
Usually doesn't harm anything.
Good Luck!
- keith1
Old hard worn valve seals typically cause exhaust smoke upon initial engine start-up, which smoking reduces or disappears after running a few miles.
Good Luck!
head was totally gone through...
- Old Man Rock
Did you use Kawi OEM valve guides or 3rd party?
Since I had additional work accomplished in my head (New exhaust valves), I had these 3rd party crap replaced with OEM guides... Babbits, $9.00 each was the cheapest OEM I could find.
In speaking with others, it seems some 3rd party stuff can cause you grief, just won't hold up as well as OEM.
Sure, some things you can get buy with, some not...
As always, I learn the hard way.... :blush:
Just a thought...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- keith1
Well since I just went through this recently due to my originally being cheap, have to ask....
Just a thought...
dave,
i had joe hooper(pitstop performance) go through the head... hes been around a long time and has a pretty good rep....i m not sure what he used as far as guides and seals,but i would be really surprised if he cheesed me on the quality...my impression is that he doesnt "roll like that"....
- Old Man Rock
I had obtained a complete gasket kit which had the seals in them... Unfortunately and not recommended from you know who and like a dumb ass I had them installed anyways...
Well guess what...sing to Doobie Bros tune "Smoke on the Water".... Smoke in the Head.... :laugh:
Not a lot of smoke but on start up would smoke for a couple seconds or so and in twisting the throttle would get a small puff....
With OEM seals, now all gone!
Ah well, keep up the post with your findings for I'm sure one or more of us will run into this same scenario in performance builds, tunning and tweaking for the optimum motor/engine builds...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Johnj
Veho vivo - Ago ut veho
- Old Man Rock
Damn, I'm getting old... :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- bountyhunter
- Thank you received: 337
