- Thank you received: 2
This could potentially suck
- keith1
about an inch above head and the 28 mark was at 10 or 11 oclock instead of 12...reset them and idles sweet...i guess i can count to 28, but i dont know what level is...:laugh:
take it for a quick test drive and bike rips....sweet....
fire up bike today and after about 10 secs on choke, it starts crop dusting the front yard...i m like "wtf?"...it did this one other time about a month ago....blowin oil...
oil pressure was good....maybe too good...guage was pinned at 14......after about 20 secs it cleared out... after it warmed up a bit.....nothing.....let it cool down a bit and fired it up again and a bit of smoke....its not the classic blue, but mostly white with a bit of blue....doesnt do it at all when up to 150degrees....i dumped the royal 20/50 oil and put in some 10/40 dino and it seemed better.....i did put some seafoam in the tank last nite and it used to make old topend make some white smoke....jugs , kit and head have a 1000 miles on em.....i m gonna try it again tommorow and put some miles on it...any ideas?
- PLUMMEN
- Thank you received: 104
- keith1
put some miles on it and see if it clears itself up
thats the plan.....if it continues, well i guess i got some decisions to make.....
- cricketfire46
83 kz750 ltd, dyna coils, k&n, mac 4->1 just rolled 50k
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Miles are probly whats needed, a few tanks.
Good luck!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- keith1
A guy I ride with had this happen last year. He dumped some royal purple in and got all kinds of smoke. He went ahead and ran it for about 3k miles. On his next oil change he drained it all and tore into the motor. Oddly enough he found that for some reason the rings looked like they had been hit with acid, the pistons were bad pitted, and the inside of the cylinders looked nasty ugly. Reworked motor, did another shot of the purple to try, nasty smoke again. drained it within 200 miles. It was starting to look nasty. cleaned it up and to this day 12000 miles later with amsoil its runs great. so evidently there is something in the purple that makes all this happen. I have read about this on other forums as well
interesting....i thought royal had a good rep and although i winced at the price, i bought it....today,i didnt change filter, just dumped oil...gonna run it for a while and change both....gotta get a filter tonite, when it gets here, dumping everything.....thankfully, i write everything down and i have only 155 miles on the 12 buck a quart at napa crap......thanks for the info....my ass kinda hurts now....oh well, part of the learning curve...
- keith1
Stay away from the purple...
Good luck!
thanks, hopefully this will be rectified by a good flush....
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- Old Man Rock
- Thank you received: 225
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Kawickrice
- Thank you received: 18
keith1 wrote:
Maybe the purple stuff will help with your pain..my ass kinda hurts now.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- keith1
Just out of curiosity... did you re-set your ignition (Dyna or points) timing once you re-set your cam timing?
OMR
i did dave.....its smack dab in the middle now on the dyna s.....would that have something to do with it?....
- Old Man Rock
NOTE: If not on the money, this would advance or retard the timing off TDC by more then 10 degrees, so it would be whacked if this is the case!
In my build and in my 105 lobe center degreeing of my cams, the DYNA S plate is rotated completely CCW and then some to get the static to hit the F mark and in obtaing advance marks in dynamic strobe light @ 2500rpm....
Obviously due to my cams versus yours, may be different but I'd verify just the same...
First do a static then dynamic... You may find the plate is where it needs to be...
Another thing is I can't remember if you're using adjustable cam sprockets... Are they correct regarding the cam degreeing to TDC?
If off, could expalin why excessive smoke due to valve openings when shouldn't be....
Not saying it is or isn't regarding the Dyna plate rotation, just something to think about and confirm just the same...
Just in case....
Dyna S write up:
kzrider.com/index.php?option=com_docman&...d&gid=449&Itemid=108
Cam Degreeing write up:
kzrider.com/index.php?option=com_docman&...d&gid=451&Itemid=108
Let us know how it works out for you...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
