- Thank you received: 337
RUNNING HOT
- bountyhunter
- BSKZ650
- Thank you received: 14
I am kind of leaning towards the lean condition myself, one quick check may be to add a little choke to it while crusing, see if the temp drops
77 ltd1000, current rider
76 kz900, just waiting
- Old Man Rock
- Thank you received: 225
Hell, I'd be happy with that number... Most automated oil passage temperature sitches I've found switch @ 180*F so you're only 20* above that....
Granted you already have a cooler but can;t remeber how many rows yours had... We're both running approximately the same build except for 60cc displacements... Your cams are .360, mine .365, different carbs but both 29mm with a megaphone exhaust... EI ignition and coils.... Pretty much the same...
Not sure how hot it gets out there but have you tested at 90-95*F ambient temps?
Either case, starting to cool down here in AZ (under 100*F now) where we're only at 97*F :woohoo: :laugh: Reseraching an Earls oil cooler now, 7-10 row. I will test once again hopefully ~ 90-95*F to compare recordings. I'll post then...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- MFolks
- Thank you received: 540
- YUKABODOS
:blink:
- keith1
(boy, they sure dont give that stuff away) and put in a new wix filter.....pulled baffle.....went for ride but cut it short as i wasnt dressed for the occasion and bike is too damn beligerent without baffle.....:laugh:
i think what i m going to do is cut out half the packing on the competition baffle and try to find some happy medium between flow and racket....i thought i had checked plugs after 29 mm install and they looked good...if anything a little rich.....i will recheck them.....thanks guys.......
- keith1
@ 75*F "i m showing 200 degrees after a 30 min ride"...
OMR
dave, what compression are you running?
- Old Man Rock
Other than displacement, pretty much the same.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- arai59
- Banned
- keith1
Your fine Keith. It's just global warming. Btw....what pods are those ? Emgo ? You might be a tad lean. Like Dave, my bike runs very hot around here. I'm too afraid to check it.:woohoo: 20w-50 would be a wise choice also.
imitation emgos....so you know quality abounds....gonna get some k and n s soon...eventually, i ll get to the bottom of problem with help from here.....hell, that motor is the result of help from here.....so far, so good....
- arai59
- Banned
- bountyhunter
The 20W-50 oils don't have the energy conserving crap in them.Watch the std car oil, since it may cause the clutch to slip.
