RUNNING HOT
15 Sep 2009 17:38 #321852 by keith1
RUNNING HOT was created by keith1
I know the 10.5 to 1 comp is probably the culprit but even at 75 degrees, i m showing 200 degrees after a 30 min ride
with a mix of cruising and stop and go....i m running 15w40 as thats all i can find in rotella/delvac around here...i m going to get some valvoline cycle oil in 10w40 and try that...i was reading somewhere on here that someone ran a thinner as opposed to thicker oil and the thinner helped with temps.....the guage i have probably isnt spot on, but should have me in the 'hood.....i have a small cooler but man, this thing gets hot fast and it doesnt come down....i m thinking over the winter i am going to pull pan, see what kind of trinkets i find in it .. i have a pump i bought a while back off a 9k mile bike that was parted out....i am pretty sure the pan has never been off this bike...any input?......thanks.....
  • oldkaws4ever
  • Have no regrets...... You only live once.
15 Sep 2009 17:45 #321855 by oldkaws4ever
Replied by oldkaws4ever on topic RUNNING HOT
how many miles on the bottom end? I would put the 9000 mile pump in for good insurince. Pulling the pan is always good just to see what the motor is really like.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
15 Sep 2009 17:54 #321858 by keith1
Replied by keith1 on topic RUNNING HOT
33k on bottom end..i checked the con-rods for slop before i installed the pistons and pins....seemed pretty decent...no dicernable side to side.....i would feel a lot better knowing that the pump is newer and and the pick-up isnt full of smeg....i have decent oil pressure, but again that guage is a ballpark....losing the steering damper and putting on a bigger cooler might be in the works also.....
  • oldkaws4ever
15 Sep 2009 18:16 #321866 by oldkaws4ever
I had right around 40,000 om my z1 when i pulled it apart, i pulled the pan and the pump, the pumwas clean, the pan was really clean to no sludge or anything. Im Going to break my 900 motor to the lower case this winter and redo everything. I was going to throw in a 1075 kit, but im 90% sure i want to 100% resore it back to showroom original......motor....pipes, wheels and finally the bodywork.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • larrycavan
  • Visitor
15 Sep 2009 18:16 - 15 Sep 2009 18:22 #321867 by larrycavan
Replied by larrycavan on topic RUNNING HOT
Just for the sake of it...try pulling the baffle and see what the temps do.
Looks like a J motor in your Avatar. I assume that's the bike. Guides were a prone to leaking on those motors and creating carbon build up in the chambers.
Any spark knock?
OMR did a hell of a good post on temps that he shot with his gun. Here's the info.
Last edit: 15 Sep 2009 18:22 by larrycavan.
  • oldkaws4ever
15 Sep 2009 18:20 #321868 by oldkaws4ever
larry, i noticed that on my kz 650 when i pull the baffle it does seem to run cooler. Why is that?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • larrycavan
  • Visitor
15 Sep 2009 18:24 #321870 by larrycavan
The heat doesn't get corked up with an open pipe. Exhaust is hot stuff ;)
15 Sep 2009 18:38 #321875 by keith1
Any spark knock?
i will definitely pull baffle..i am going to pull megaphone as i put it on a rear stand to give me a little room to get underneath to change oil..i have to lube chain also....i get spark knock at about 190-200 degrees.....not a j motor though....stock 78 motor was there when i got bike....head all redone..new guides and seals....mtc forged pistons...850 miles on top end....i guess 200 isnt really that hot by looking at omr s oil temps....what should these bikes run as an average temp?.....thanks for your input larry........
15 Sep 2009 18:39 #321879 by keith1
motor pic
15 Sep 2009 19:25 - 15 Sep 2009 19:25 #321891 by bountyhunter
Replied by bountyhunter on topic RUNNING HOT
make sure it's not running lean because that makes it run really hot. Also, check timing advancer since running the timing fast will also make it run hotter.
Last edit: 15 Sep 2009 19:25 by bountyhunter.
15 Sep 2009 19:26 #321892 by bountyhunter
keith1 wrote:
motor pic
pretty.
16 Sep 2009 06:37 #321948 by keith1
thanks.....
