kz900 strange engine noise
  • OldSchoolHr
  • OldSchoolHr's Avatar Topic Author
  • Kawasaki z900a4 1976 Croatia, Europe
Re: kz900 strange engine noise
10 Jan 2010 04:42
#342419
Intake shims 2 & 3 looks worst but they arent. The worst are ex. shims 1 & 3. See variations in thickness on them.
Cams lobes are perfect, there arent any signs of wear on them. Grinded side of shims was laying on valve tappets.
And yes, I will replace them all.
  • Old Man Rock
  • Old Man Rock's Avatar
10 Jan 2010 04:58 - 10 Jan 2010 05:00
#342421
Replace... Excellent!
Wonder is some of that filings made it's way down into the valve guides thus improper valve operations/lubrication's thus engine noise... Interesting indeed...
BTW, I found out the Triumph shims (29mm diameters) are the same as the KZ's... ;) Since being in Europe, would think you'd be able to find a local dealership no prob....
Found a local source here at the Triumph dealership... $6 each... Sweet! B)
Jeff @ Z1 has them as well, pretty much the same price minus shipping costs...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 10 Jan 2010 05:00 by Old Man Rock.
  • OldSchoolHr
10 Jan 2010 10:32
#342454
OMR
What is the quality of that aftermarket shims? Does anyone use them?
  • kaw1425
  • kaw1425's Avatar
10 Jan 2010 19:28
#342521
that sound is the timing chain hope this helps
  • z1wiz
  • z1wiz's Avatar
10 Jan 2010 20:03
#342524
(Quoted from earlier in post) Few days ago I took off alternator cover but I didnt pull off rotor and starter clutch. I have visualy inspected is anything broke or loose and the only thing that seemed suspicious, big gear behind starter clutch has a little left-right play (direction rotor-casing)maybe 1-2mm
I dont know is it suposed to be ok or not. Everything works.
The big gear behind the starter clutch is supposed to have a rubber damper between the gear and the case to put a little bit bit of drag on the gear. If the rubber damper is in place, there would not be 1-2mm play. Don't know if that is the origin of your noise or not, but that doesn't sound right.
Russ
Over 30 years with z1's, Currently down to only one 75, a j model dragbike, and 2 KZ1000 dragbikes.
  • OldSchoolHr
10 Jan 2010 20:35
#342527
Russ
Yes, I know, but that gear is not spining when engine is working so I think that its not source of that knocking.
  • OldSchoolHr
10 Jan 2010 20:38
#342528
I have also suspect on timing chain, but it is new same as all rubber dumpers, tensioner, front guide and center roller :(
  • z1wiz
  • z1wiz's Avatar
10 Jan 2010 20:50
#342531
But, could the gear possibly be moving back and forth making the noise?
Russ
  • Zedone
  • Zedone's Avatar
14 Jan 2010 00:35
#342833
OldschoolHr, How are you making out with your engine? Find anything new? Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
  • OldSchoolHr
14 Jan 2010 06:01
#342844
Nothing yet. I ordered new shims so I am waiting to come. And mentally resting from the hunt for the dragon :laugh:
At least no one can say that we, owners of Oldschool bikes, are bored in life :woohoo:
  • OldSchoolHr
26 Jan 2010 11:31 - 26 Jan 2010 11:32
#344678
Ok, I have replaced old shims with new ones from z1e and, as you can guess, I DIDNT resolved mystery :huh: Knocking still lives :lol: Ooh my, I am tired :side:
[img
Last edit: 26 Jan 2010 11:32 by OldSchoolHr.
  • Zedone
  • Zedone's Avatar
03 Feb 2010 00:41
#346179
That is uncool, do you have another oil pump. I'd install a oil pressure gauge at the base of the block and pull the oil pump & replace it with one that is 100% good, just for peace of mind, I'd hate to see you blow up that engine over a $25 part. Regards, Doug
1977 KZ1000A1
