kz900 strange engine noise
- trianglelaguna
Re: kz900 strange engine noise
12 Sep 2009 09:19
maybe not though.....the first clip would also have the noise cold or hot??????loose bore....worn/dammaged rings on a cylinder?????
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- Locozuna
12 Sep 2009 09:32
In the first video at about 1:23 I see your exhaust flange is about 1/2 inch off the engine. No way can I see that much of my 1/2 clamshells. On my 900 this would be leaking bad. My flanges come up close to the engine bolt boss. A lot closer than this. Is it possible you just have the exhaust too loose?
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- Splandman
12 Sep 2009 10:05
I have nothing useful to add...except that's a rally nice bike.
and GO CROCOP!
and GO CROCOP!
Current Bikes
1980 KZ1000E
1980 KZ1000E
- OldSchoolHr
- Kawasaki z900a4 1976 Croatia, Europe
12 Sep 2009 10:09 - 12 Sep 2009 10:10
Exhaust flange are ok. My headers are custom made. I made them from stainless steel and I dont need exhaust inserts cos I weld rings on header tubes. Just like new modern bikes have.
My Gallery -
www.wix.com/limit2/z900
Last edit: 12 Sep 2009 10:10 by OldSchoolHr.
- OldSchoolHr
12 Sep 2009 10:30 - 12 Sep 2009 10:33
trianglelaguna wrote:
Few days ago I took off alternator cover but I didnt pull off rotor and starter clutch. I have visualy inspected is anything broke or loose and the only thing that seemed suspicious, big gear behind starter clutch has a little left-right play (direction rotor-casing)maybe 1-2mm
I dont know is it suposed to be ok or not. Everything works.
i listened to the youtube clip before reading the last below staement....and was thinking the same thing,when you had the camera down on the chain cover area i could hear it clearly, the starter gear or a bolt working free in the alternator,stator and cover ect.. or somthing like that.....when you pull that cover i bet you see the grind spot and culprit....any shavings in your oil???....unbelievable bike...just really...really niceOldSchoolHr wrote:
My Gallery -
Last edit: 12 Sep 2009 10:33 by OldSchoolHr.
- timebomb33
12 Sep 2009 10:37
it is very hard to tell from the video but if the sounds go away at higher rpm's and are just occuring around the idle rpm and it seems to me that it is happening in phase with the crankshaft rotation it could be the springs in the backing plate of your clutch basket over time they will pound out and get loose in the mounting slots that is why there are heavy duty spring and rivit kits available from outfits like ape, m.t.c and falicon. try listening around the clutch basket area a little closer .in all my high performance bikes i replace the stock baking plate springs and rivits because they do loosen up badly under hard acceleration and over time.
I THINK MY POWERBAND BROKE
- keith1
12 Sep 2009 16:50
OldSchoolHr wrote:
from the sound of vid, starter clutch area would be my guess....i dont think that big gear should have that much play either....i would get an ape manual cam chain tensioner also...but then again, what the hell do i know....nice bike by the way......
trianglelaguna wrote:i listened to the youtube clip before reading the last below staement....and was thinking the same thing,when you had the camera down on the chain cover area i could hear it clearly, the starter gear or a bolt working free in the alternator,stator and cover ect.. or somthing like that.....when you pull that cover i bet you see the grind spot and culprit....any shavings in your oil???....unbelievable bike...just really...really niceOldSchoolHr wrote:
- TerryK
12 Sep 2009 21:39
I was going to say exhaust leak as we but if you lean it to the right and the noise goes away, it's possible you have low oil pressure. When you lean it right a small amount of oil quiets a noisy bucket.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- OldSchoolHr
13 Sep 2009 10:31
Today I pull off rotor and starter clutch. Rotor bolt was tight, starter clutch bolts were tight also. No sign of wear on starter clutch springs, pins, rollers, big starter gear or anything else. Everything look like new.
Next to review is right side, clutch and clutch basket.
My Gallery -
- larrycavan
13 Sep 2009 15:07
Tough to tell from the videos. Sure sounds like cam chain to me though.
I would bring it to TDC on 1&4 and yank the tensioner. See if the plunger is sticking.
- OldSchoolHr
14 Sep 2009 00:53 - 14 Sep 2009 07:47
Last year I rebuild complet head, put new chain tensioner, central roller, all dampers, front chain guide...everything from this picture in red colour is replaced with new parts.
Few days ago I pull off valve cover and check everything again. Chain has tension and it seams ok. I pull of chain tensioner and reset it. It is clean and works just like new.
To avoid any doubt about cam chain I bought a new one, Tsubaki, so I will replace it in next few days.
The only thing that I cant see is front chain guide. When I was rebuilding head I found that guide was broken so I replaced it with new one. I cant see is it broken again but that would be weird cos I passed only 3-4000 miles since then.
My Gallery -
Last edit: 14 Sep 2009 07:47 by OldSchoolHr.
- OldSchoolHr
14 Sep 2009 08:06 - 14 Sep 2009 08:06
I opened clutch cover and I think that I havent got clutch assembly from kz900a4 model :ohmy: Does anyone know from which model of Kawasaki is this clutch assembly?
My Gallery -
Last edit: 14 Sep 2009 08:06 by OldSchoolHr.
