kz900 strange engine noise
  • OldSchoolHr
  • OldSchoolHr's Avatar Topic Author
  • Kawasaki z900a4 1976 Croatia, Europe
Re: kz900 strange engine noise
07 Oct 2009 05:50 - 07 Oct 2009 06:13
#325967
Does anyone know what is purpose of this part 92043-109 PIN
on output shaft. I mark it with blue colour dot on first picture.
It seems that someone put transmission from kz1000a4 in my engine. I cant see that part anywhere on my transmission.
The diagram of kz1000a4 does not show this part. Also on my shaft, I have this type of nut and washer as indicated with red dots on secon picture.
Help pls!
[img
[img
Complete clutch is probably from kz1000e2 shaft. Same as on this picture.
And everything works just fine. Amazing :dry:
[img
Live from the place of ongoings!
[img
Last edit: 07 Oct 2009 06:13 by OldSchoolHr.
  • OldSchoolHr
11 Oct 2009 11:57
#326810
on output shaft of transmission?
My shaft is from Mk2 model and it has no hole for this pin.
  • OldSchoolHr
20 Oct 2009 07:20
#328564
While I am waiting for my parts to come I played little with my dremel tool.
92
92
92
92
92
92
  • OldSchoolHr
20 Oct 2009 07:24
#328566
And this is what it came
92
92
92
92
92
92
92
92
92
92
92
  • OldSchoolHr
11 Nov 2009 08:14 - 11 Nov 2009 08:15
#332838
larrycavan wrote:
Shake, rattle & roll is the norm for the basket springs in those motors. There is an upgrade kit APE sells with heavy springs, new backing plate and rivets that you weld. Might be worth the piece of mind you'd get from it...
Generally though, those baskets work just fine unless you're severely abusing it at the drag strip every weekend. Scarey to hold that thing in your hand and listen to that rattle but in all honesty, they are solid baskets.
Case looks repairable. A good welder shold be able to handle that.If you end up needing them. They're all over ebay. Look under dragbike. Prices are way down on that sort of thing.
It's your nickle but IMO, you're best bet is tear everything down and go through it carefully. Check your transmission bearings out as well.
If it turns out you had oil problem to top end and cams are worn...holler...I've got several sets of stockers. You can have a set for free if you need them...
This is what I found when I opened it.
Cam chain is rusted on one place. Maybe its been knocking. Also, I found a marks from camchain on crankshaft cap :ohmy:
[img
[img
Also, I found a circlip from shift rod is fell of
[img
[img
And my transmission ball bearings are worn out
[img
[img
[img
[img
I dont know what of this, could make a noise like my zed was makeing?
Last edit: 11 Nov 2009 08:15 by OldSchoolHr.
  • Old Man Rock
  • Old Man Rock's Avatar
11 Nov 2009 08:32
#332844
WHoa... First image, top idler assembly....
You found the bolts raised as depicted in the image?:blink:
If holds true, check the inside of the valve cover for markings.....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • OldSchoolHr
11 Nov 2009 09:10 - 11 Nov 2009 09:13
#332851
No, I loose that bolts :) There are no markings inside valve cover.
Last edit: 11 Nov 2009 09:13 by OldSchoolHr.
  • OldSchoolHr
11 Nov 2009 09:24 - 11 Nov 2009 09:29
#332854
Transmission gears are like new but bearings are worn.
So I bought all bearings inside engine.
- 2 ball bearings for input and output shaft
- 2 needle bearings with bushings for input and output shaft
- 1 needle bearing with bushing for clutch basket
- 1 needle bearing for starter clutch gear
- output shaft
- starter clutch assembly
All of this parts I found at www.kawasakinosparts.com/index.php
Prices there, are lowest I could find.
[img
[img
[img
[img
[img
[img
Also I bought clutch basket rebuild kit, springs and rivets, from Ape. Does anyone knew procedure for rebuilding cluth basket? I thought that I saw some posts with pictures of that on this forum, but I cant find it now.
Last edit: 11 Nov 2009 09:29 by OldSchoolHr.
  • OldSchoolHr
12 Nov 2009 06:16
#333081
Transmission is done.
[img
[img
[img
[img
I am just waiting ape kit to rebuild clutch basket and engine can be assembled.
  • larrycavan
  • larrycavan's Avatar
12 Nov 2009 15:02
#333163
Looks like you're covering all the bases pretty well.
Blow out all the oil passages real well. Don't forget the tranny oil passages.
Loktite the oilpump mount bolts.
  • OldSchoolHr
17 Nov 2009 12:54
#334316
I received APE clutch basket kit and already disassemble
clutch basket. Tomorrow I will take it to the machine shop
to expand rivet holes and to press rivets in. I am only concerned about this heavy duty springs. Original springs
are 3*thiner and 3*thicker and this springs in APE kit are
all thicker. I dont know how it will be shown in practice
Whether the clutch would have strong shocks or something
else??
Is there anyone on the forum to have some experience with heavy duty clutch?
92
92
92
92
92
92
92
92
92
92
92
92
92
92
  • OldSchoolHr
14 Dec 2009 08:49
#338925
Clutch basket is done. I didnt weld it, just put new rivets. Heavy duty springs are longer for 0.5mm and there is no play in those springs anymore :)
[img
[img
[img
[img
