Advice on my turbo thoughts
- Headly
23 Aug 2009 02:51 - 23 Aug 2009 03:04 #315885
by Headly
73z1a fireblade front&rear,75z1b,74z1a,05 husky 510,xl567.
Ask the toe cutter,he knows who i am!
Replied by Headly on topic Advice on my turbo thoughts
try again
Last edit: 23 Aug 2009 03:04 by Headly.
- Headly
23 Aug 2009 03:38 #315893
by Headly
This is the third time i have tried to post a pic,i downloaded pixresizer and ran my photo through but it still wont accept the file size,ill try once again if it doesnt work this time i will give up tonight before i put my fist through the f*&#$@g screen,sorry!
- Thank you received: 2098
23 Aug 2009 04:03 - 23 Aug 2009 04:04 #315895
by Patton
Replied by Patton on topic Advice on my turbo thoughts
The computer operating system may already contain a resizing program without needing to download anything else.
If not already tried, right-click the thumbnail image in the computer's picture file.
Does a resizing choice appear in the menu?
If so, left-click it, and go from there.
Here's what the menu may look like.
Last edit: 23 Aug 2009 04:04 by Patton.
23 Aug 2009 04:05 #315896
by Patton
23 Aug 2009 04:08 #315897
by Patton
23 Aug 2009 04:14 - 23 Aug 2009 04:14 #315898
by Patton
Left-click the "OK" box.
A new thumbnail of the re-sized pic should now appear in the picture file alongside the thumbnail of the too-large picture.
Good Luck!
Good Luck!
Last edit: 23 Aug 2009 04:14 by Patton.
23 Aug 2009 04:18 #315899
by Patton
The above sequence is from Microsoft Windows XP home edition.
Other versions should be similar.
Good Luck!
Good Luck!
- Headly
23 Aug 2009 04:23 #315901
by Headly
Gday Patton,the only thing that comes up when i right click is the menu to rotate,edit etc,etc but no resize image.What version of windows do you run? Ive got vista.(thanks for your help by the way)
23 Aug 2009 04:31 - 23 Aug 2009 04:49 #315902
by Patton
When in the message box typing up the new posting,
there is a way to change the image size before clicking the "Submit" box.
The procedure is something like adding [1mg size = 550] before or within the "[1mg]" that appeared in the message after clicking the "[1mg]" box.
Will rely on someone else to better explain this.
Good Luck!
Memo -- The numeral 1 is substituted for the letter i within the brackets (to avoid activating the tag).
Good Luck!
Last edit: 23 Aug 2009 04:49 by Patton.
23 Aug 2009 04:36 #315903
by Patton
Am unfamilar with Vista.
But wondering if the "Edit" choice might prove fruitful.
23 Aug 2009 04:44 #315904
by Patton
Here's a thread that may be helpful.
About the Site
The thread is located under forum "Categories" in the Non-Technical thread "About the Site."
Good Luck!
About the Site
Good Luck!
- Headly
23 Aug 2009 04:59 - 23 Aug 2009 05:07 #315905
by Headly
Last edit: 23 Aug 2009 05:07 by Headly.
