Advice on my turbo thoughts
- Headly
20 Aug 2009 22:35 #315452
by Headly
73z1a fireblade front&rear,75z1b,74z1a,05 husky 510,xl567.
Ask the toe cutter,he knows who i am!
Advice on my turbo thoughts was created by Headly
Hello to all,thinking of putting the turbo kit from my gs 1100 onto my z1b as its time to cut back on toys(too much rego costs etc)and as id rather the kzs the suzi might have to go,so heres the story.Mr turbo headers and link pipe,rebuild rayjay that came with mr turbo kit,microtech computer,bosch injectors and fuel pump,custom made plenum and throttle body,mr turbo water injection,etc,etc.
Never had the suzi running with the turbo stuff so basically its like new.I can modify the headers and stuff to suit the kz myself as i have access to a engineer shop.Questions are- 1.can i run stock 1000 pistons on low boost as i already have a set here,what size spacer plate do you think ill need for say 8-9:1 compression(i dont know what stock comp ratios are for kz900).
2.i have a set of wiseco 1045cc 10.5:1 pistons can i mill the dome down to drop compression?
Dont want to run high boost just want to up the power and may as well use the turbo stuff as ive already got it lying around,cheers for your opinions guys.
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
20 Aug 2009 22:47 #315453
by kzz1p
Replied by kzz1p on topic Advice on my turbo thoughts
No spacer plate is needed for the pistons. They are appx. 8.5:1 stock. Save time and buy a exhaust pipe. Because you can make it fit, doesn't mean it will work. Your suzuki plenum
isn't going to fit. The computer and injectors, who knows? Maybe you would be better off, with a simple old school, Z1r type set up?
- Headly
21 Aug 2009 02:13 - 21 Aug 2009 02:15 #315480
by Headly
Replied by Headly on topic Advice on my turbo thoughts
My mates an alloy welder so making another plenum wont be hard as he made this one for the suzi,the injectors and computer are aftermarket so can be used for any make ill just have to get him to help me re-map it to suit the smaller ccs i guess,your probably right about the headers though could be easier maybe building a set from scratch or try and buy a set and link pipe for a kz.Do you know if there is a thread with the old z1r type you are talking of,thanks.
Ill try to post some pictures soon,my hard drive fried itself a few days ago and we lost the lot,only got this new computer yesterday :blink:
Last edit: 21 Aug 2009 02:15 by Headly.
- kzz1p
21 Aug 2009 13:15 - 21 Aug 2009 13:19 #315533
by kzz1p
Headly
I just saw a used exhaust on the net for sale. It was old and rusted, but a mr turbo! I'm not sure, I think it was under "yahoo images" kawasaki exhausts. If you want pictures of turbo pipes? I'm your guy. I am sure that I have, alot of them. You might check out some of my latest posts on "Misc Motorcycle Photos" There is a black Z1r with a mr turbo kit. Was this old style pipe, called a spyder pipe? There are newer styles.........
Last edit: 21 Aug 2009 13:19 by kzz1p.
- kzz1p
21 Aug 2009 13:27 #315542
by kzz1p
- kzz1p
21 Aug 2009 13:41 - 21 Aug 2009 13:43 #315545
by kzz1p
Last edit: 21 Aug 2009 13:43 by kzz1p.
- kzz1p
21 Aug 2009 13:44 #315547
by kzz1p
- tooocool49723
21 Aug 2009 15:05 #315562
by tooocool49723
'82 KZ550 "Project"
First bike, 30k miles
Ann Arbor, Mi
Replied by tooocool49723 on topic Advice on my turbo thoughts
Wow, those setups look like it'd be very warm on the legs there! 900 degree EGT's mere inches from a leg seems... interesting to say the least!
'82 KZ550 "Project"
Ann Arbor, Mi
- Headly
21 Aug 2009 16:46 #315571
by Headly
Looks very similar to the set up ive got,ill take some photos today and post them tonight so you can have a looksee,thanks for your help.
- Headly
22 Aug 2009 16:39 #315787
by Headly
Heres a few quick pics of my stuff,sorry about the quality but you get the idea.
If i take about 2mm of the diameter of the header flanges with a die grinder they will bolt up to the kz head with a little help they are very close,which surprised me,the link pipe fits pretty well i will definately have to make another plenum as this one is way to thick although it did fit my manifolds(probably because i have the larger GPZ1100 manifolds).If i used the wiseco 1045 pistons do you know what thickness spacer plate i might have to run to drop compression from 10.5:1 to 8.5:1?
- Headly
22 Aug 2009 16:43 - 22 Aug 2009 16:51 #315790
by Headly
having trouble with file size says it exceeds admins limit how do i reduce size so i can show photos? :huh:
Last edit: 22 Aug 2009 16:51 by Headly.
- toadson
- Thank you received: 1
22 Aug 2009 23:16 #315873
by toadson
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
Replied by toadson on topic Advice on my turbo thoughts
You can get a free program called Pixresizer that resizes images on your computer. I upload all my pics to Photobucket.com and they have an option to resize them also. I usually just size them to 640X800 and it works great for posting pics on this forum.
