- Thank you received: 10
Before I burn this bike.....
- timebomb33
18 Jun 2009 12:50 #300300
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Before I burn this bike.....
where are you located in the great white north.
- Born Dead 2
18 Jun 2009 13:02 #300305
by Born Dead 2
Replied by Born Dead 2 on topic Before I burn this bike.....
timebomb33 wrote:
New Brunswick. And yourself?
- kawsakiman
- Thank you received: 6
18 Jun 2009 15:40 #300371
by kawsakiman
Replied by kawsakiman on topic Before I burn this bike.....
popping on decell could also be a faulty air injection system.
+1 on a good cleaning then using compressed air to make sure all the passages are clean.
- timebomb33
18 Jun 2009 15:47 #300376
by timebomb33
sask/alberta depending on the time of year. canadian bike wont have air injection thank god.
- kawsakiman
18 Jun 2009 16:01 #300384
by kawsakiman
timebomb33 wrote:
oppps! forgot about that!
- Born Dead 2
22 Jun 2009 06:00 #301283
by Born Dead 2
So heres the latest on my carbs. Spent the weekend cleaning these and man they were nasty!!! I let them soak Saturday night and cleaned every orfice with a guitar string. Found a few clogged jets and lots of gummed up passages. So now the carbs are so clean I could drink beer out of them, if it wasn't for the toxic cleaners I used in them. Hopefully I'll get these on tonight and everything goes well.
I'll keep you updated.
BD
BD
- timebomb33
22 Jun 2009 12:49 #301375
by timebomb33
air pressure is good use lots
- Born Dead 2
23 Jun 2009 05:28 #301507
by Born Dead 2
timebomb33 wrote:
Oh yeah, lots was used.
- WABBMW
- Let The Good Times Roll !
- Thank you received: 16
13 Jul 2009 07:47 #306689
by WABBMW
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Replied by WABBMW on topic Before I burn this bike.....
It really sounds like the idle circuits are still not flowing like they should - hence the lean condition at idle and popping at closed throttle. Since the pilot jets are so very small, it does not take much to stop them up. I have cleaned the jet itself with carb cleaner and some tiny wires. From these jets, the fuel goes over to the adjustable idle mixture screws, where the amount of air and fuel are balanced by adjusting the screw. Past this, the fuel goes into the throat of the carb.
I have seen cases where the pilot jets were clean, the air adjustment screw cavity was clean, BUT THE TRANSFER PASSAGE FROM THE PILOT JET TO THE AIR SCREW IS PLUGGED. I would be willing to bet that this is what is wrong in your case. If this is true, then the adjustment screws will not seem to make any difference when they are turned. If the pilot jet is removable, then do so very carefully - get a screwdriver that fits the groove exactly so you won't round off the brass groove and not get the jet out. Then spray carb cleaner into the pilot jet orifice at full force, plus blast compressed air into it, hoping the material will dislodge and flush on through.
If the jet is not removable, then spray cleaner into the jet, then compressed air. Repeat about 1000 times, keeping your fingers crossed. Perhaps someone else will chime in with a better method. Good luck.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
