Before I burn this bike.....
- Born Dead 2
So my question is what the hell am I not seeing here? Everything is clean in the carbs, new battery, plugs, wires, everything is in spec, cam chain is rattling a bit, but I can't see that being the culprit or could it be?
It seems to be in the pilot circuit somewhere.
Anyone who has seen or had this problem?
Thanks in advance
BD
- OKC_Kent
- Thank you received: 20
Fresh gas and a few tanks of Seafoam treatment. Adjust the idle up a bit.
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- austin3119
- Thank you received: 7
Lol Kent beat me to it. Seafoam is good stuff.
- Born Dead 2
Until someone else chimes in with another suggestion have you tried new fresh gas?
Yup, fresh gas actually 2 tanks later. Haven't tried the seafoam yet. As far as adjusting the idle, When I adjust it up to 1100-1200 rpm's it'll idle fine until it warms up and then it goes up in idle and I have to adjust it back down.
doesn't seem right to me.
- Born Dead 2
your idle circuits may have gotten gummed up/clogged and a good cleaning of all removable parts in the float bowls..in a little tub of carb cleaner two inches deep six around and a fine strand/strands of copper wire to pass through orifices carefully so as not to break off wire in a jet....you'll need a good diagram of you EXACT carbs a tiny flat head and a blow up of where the little circuits are tucked away...also spraying the passages out and resoaking thrttle bodies a few times is important...the choke issues and the popping are my clues to the idle circuits being clogged.....good luck...just my guess....if it is and you pull the carbs and get em squeeky clean you'll notice a dramatic effect....
I did clean the carbs this season already and put all new orings and seals in them. Thanks for all the responses. Also here is a stupid question for my fellow Canadian wrenchers. Where can I get this seafoam you speak of?
Thanks again.
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Make sure (clear hose) that a nice thick stream of fuel is getting in there under full choke.
... and that there is absolutely no air/fuel leaks anywhere possible in the system.
Cheers, n' good luck!
Fellow Canadian wrencher.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Born Dead 2
the idle circuits are tiny/and out of the way and often get missed on inspecting for a cleaning...you may want to see a blow up and dble check that you got to em...i also had done cleanigns and adjusting and was not seeing em till my same problems arose...my 2 cents
Thanks man, I'll tear the carb down again and go through it. Also I am going to run the seafoam. Where can I get that in Canada?
Thanks again
- saxjonz
- KawboyZ
- Thank you received: 76
Popping is carb related, possibly electrical and also even headgasket like my 80 z. I would accellerate hard and then when I would back down it would pop. I noticed a small oil stain on the block and to my dismay I found that the PO had overfilled the oil at one point which is about the only effective way to blow a kaw gasket. :huh: :lol:
79 LTD B3
- saxjonz
- KawboyZ
79 LTD B3
- saxjonz
- KawboyZ
Thanks again
79 LTD B3
