Timing on an 82 csr
- buckinrut25
- bountyhunter
- Thank you received: 337
I suspect the power will be the same as other 750 twins (55 HP).
- smzebel
- buckinrut25
85 750 csr
- bountyhunter
I think the crankshaft on the 750 twin turns CCW, so twisting the plate in the clockwise direction should advance the spark, move it CCW to retard the spark.
- buckinrut25
- Thank you received: 2098
Good Luck!
- bountyhunter
I'd put it back to the original stock position and ride it if it runs well that way.I have an electronic pickup that has no slots in it just 2 screw holes i see no way to move it bikes running really strong thru out the power band but the timing is right in the middle between the F and T at 1000rpm so i cut grooves to get timing on the F and runs like crap popping thru carbs I was really careful while timing the cams. could i have them off a bit with it running good is it worth messing with or am i chansing more damage thanks
Always good advice to clean and lube the mechanical advancer if it has one. After a while, the grease gunks up on them and they stick.
