Timing on an 82 csr
- buckinrut25
thanks jerry
- Link14
- Thank you received: 6
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- bountyhunter
- Thank you received: 337
well I put oil in the clylenders and rechecked the compression it went up to 108 in the left and 112 in the right looks like im due for a set of rings
I would expect to see higher if it was mainly rings. The valves are probably not sealing well.
- bountyhunter
the store by my house is crazy on their prices were is the best place to buy all the parts for it at a good price that ships quickly
I found some good new valves on ebay pretty cheap for my 750 twin. I think the seller was RustyRiderLLC.
You can get brand new oversized OEM piston/ring sets for about $72 (set of two) in sizes of +0.25mm - +1.0mm from a place called cyclewareables.com. You won't find those any cheaper.
www.cyclewareables.com/pages/vintage_pis...age_piston_rings.htm
NOTE: If you need valve guides, I have a full set of actual Kawasaki brand new OEM guides I will sell at a discount.
Old Bike Barn used to sell the valve shaft seals for the 750 twins. They are very hard to find.
In general, the best places for parts are:
Z1 Enterprises
babbittsonline.com
old bike barn
- Thank you received: 2098
...check valve clearances and retest....
Have valve clearances been checked and if necessary adjusted to specs?
Would also consider a leak-down test to more precisely indicate where compression is escaping.
Good Luck!
- buckinrut25
- bountyhunter
The athena gasket set listed above is about $79. I used that set for my rebuild. The head gasket was good but the cylinder base gasket failed and I had to tear it down again to replace it. The valve cover gasket was pretty much crap as well. That set does NOT come with valve seals even if it says it does. IMHO, it is not a good deal and you should NOT use the base gasket, use it as a stencil and buy some good gasket material at Auto Zone..
- buckinrut25
- bountyhunter
God only knows what was done before you got it, but it is easy to see what you need to do to fix it if you have accurate measuring tools and all machine shops have those.
- bountyhunter
I have a '79 manual:I still havent recived the manual that I bought on ebay so I have no specs to mic the pistons or cylender or should I just hsve the jugs bored and buy pistons to match thanks again for ant help
cylinder inside diam (FOR STOCK PISTONS):
standard 78.000-78.019mm, less than 0.01mm difference between any measurements going from top to bottom.
service limit: 78.10mm, .05mm difference between any two diameter measurements going top to bottom
Piston-cylinder clearance: standard 0.043 - 0.070mm
piston diameter: standard 77.94 - 77.96mm
service limit: 77.8mm
piston ring-groove clearance: standard 0.01-.05mm
limit: 0.15mm
ring end gap: standard 0.2-0.4mm
service limit: 0.7mm
- buckinrut25
