Timing on an 82 csr
19 Apr 2009 08:51 #283073 by buckinrut25
Timing on an 82 csr was created by buckinrut25
Hi I recently got a good deal on an 82 kz750csr and im having trouble finding a manual for this bike the bike is hard to cold start and has h hesitation under hard acceleration runs fine under normal driving conditions i do have a lean condition im thinking its becuse it has open exhust and k&n air filters and carbs havent been jetted i cant seem to find any one who knows a good jet setup for this one i have already tuned thid bike up with a new coil pickup plugs and wires and i checked the valve adjustment and all are within the specs i have not figured out how to check or adjust the timing yet im thinking that may be the place to start before i go to the jets i have compleatly cleaned the carbs thanks for any advise you can give sorry this is so long
19 Apr 2009 09:27 #283074 by buckinrut25
Replied by buckinrut25 on topic Timing on an 82 csr
I also ran a compression test on the engine i have 95lb in both clynders but im not sure were it needs to be
19 Apr 2009 10:23 #283080 by JMKZHI
Replied by JMKZHI on topic Timing on an 82 csr
250400049499
19 Apr 2009 12:56 #283106 by buckinrut25
sorry im not sure what that means
19 Apr 2009 13:21 - 19 Apr 2009 13:26 #283108 by Buda
Replied by Buda on topic Timing on an 82 csr
No eBay APP ID and/or Cert ID defined in Kunena configurationThis is what he means. If you plan on having that bike for a while it is worth having around and will answer most of your questions.
Tom
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
Last edit: 19 Apr 2009 13:26 by Buda.
19 Apr 2009 13:28 #283110 by buckinrut25
Thanks for the link i just bought the manual i would still like any advise anyone can give
19 Apr 2009 14:46 #283121 by bountyhunter
Replied by bountyhunter on topic Timing on an 82 csr
Nominal compression for a 750 twin is about 150 psi, service limit is 115 psi. Did you try an oil squirt in and recheck the compression? That will tell you if it is rings.
If you are running "open exhaust" which I assume means no mufflers, it will run terrible. If your post :
k&n air filters
means you are running pods, that will make it run worse. You will need richer jets and probably to move the needles to a richer setting.
My 750 twin came with 45 pilot jets and 125 mains stock. You can still get new pilot jets and I have found 50 pilots run better with my headers.
There are no replacement main jets available that I know of.
19 Apr 2009 14:48 #283122 by bountyhunter
First torque the head, check valve clearances and retest. If the compression is still that low, the engine needs work. Probably a valve job.
19 Apr 2009 14:51 #283124 by bountyhunter
using a timing light: On mine, the letter "F" must align with the timing mark at idle. At RPM above 3000, the timing mark must align with the two parallel lines.
19 Apr 2009 14:57 #283126 by buckinrut25
thanks ill put oil in and recheck the compression in the morning i thought that was a little low were is the best place to get the larger pilot jets and yes i do have pods i do have mufflers but they are flow thru and have almost no resistance i need to redo the exhust but im going to stay pretty open kinda weird when i pulled the plugs they were a light brown though about were id expect them to be what should they look like
20 Apr 2009 06:57 #283289 by ronjones
Replied by ronjones on topic Timing on an 82 csr
Ya might want to take a look @ how I solved the jetting for pods problem. She's been running so well that I still haven't put the 122.5 mains in. BTW both main and pilot jets are still quite available for the BS34's used on the '82 750CSR.
tinyurl.com/dfasyq
Ron
20 Apr 2009 14:29 #283376 by bountyhunter
tinyurl.com/dfasyq
Ron
Lucky they are BS34's. There are no main jets available for th BS38's used on the earlier twins like mine.
You can get jets at Z1 enterprises.
