- Thank you received: 109
cam timing question
- mark1122
- Keep twisting it
it's easy to get the bottom oil rail ring installed incorectly. they can slip out of the groove when u push the piston into the cyl.Dont even ask me how i know that.:blush:
I had brand new oil seals go bad last year too. they just got stretched, hard and deformed. sounds like growing old.:lol:
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- keith1
- Thank you received: 2
Hahaha.... I was like, "O-ring?? Oh shit...." but yes, I DID put that piece in. I didn't really think of that as an "O" ring... haha...
I also see that Z1 has a one piece copper gasket.... I might just have to get that.... I mean, the ones I have on there now are brand new and they're leaking... so maybe a one-piece is the way to go???
i was advised against copper unless cylinders are o ringed.....sold mine...go with a cometic one pc gasket
and fill that o-ring area with high temp gasket stuff...i ran mine for about 1/2 an hour twice and no leaks....gotta get some carbs on it and away i go.....good luck....let us know how you make out......keith
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Bicycle Lee
/ok thats all good then, unless it got bumped out of place or something. the smoke should only last for a min or 2. if it keeps smoking u have oil geting into the cyl somewhere.
bottom oil rail ring? You mean one of the piston rings?
hmmmm.... I hope I don't have to take it all the way down to the crank again..... fitting those pistons in sucks haha
I can't find a one-piece cometic head gasket on Z1.... do they have one?
1978 KZ1000 police
- Bicycle Lee
Still looking for that one-piece Cometic head gasket....
anybody got a link for it?
1978 KZ1000 police
- Little B
- Thank you received: 3
1981 KZ750-H2 LTD
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mark1122
- Keep twisting it
So my brother seems to think it's an issue with my carbs... something that was there before. I drained my oil before and there was a lot of unburnt fuel in it. He seems to think my floats are off, or something. Still looking to get new carbs anyway, but I figured it would be worth a try.
Did u check your oil again to see if there is gas in it again?
if u have . your float hieght may be high, or the seats may be leaking. To check the seats,Turn the gas off ,take the carbs off a bit, hold them level. Now turn the gas back on. is there gas leaking out on either side of the carb?
if it is, witch 1 or all? remove the seats and see if they are dirty or warn. replace if neccesary.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Bicycle Lee
1978 KZ1000 police
- Bicycle Lee
- Bicycle Lee
Anybody else have ideas on what I should do?
The head gasket for sure needs to get replaced, but the high idle and smoke is still bothersome too...
1978 KZ1000 police
- keith1
so I'm going to try and make this thing not smoke or leak before I even bother putting it back in the frame.
just a shot in the dark, but the head gasket could also be leaking into adjacent cylinders and causing excess oil in cylinders (smoke) as well as leaking
externally.....
