cam timing question
- Bicycle Lee
Now, my question is, looking at my attached picture (in which I've crudely drawn the > timing mark on my exhaust cam) the mark is now above the level of the head, but if I were to align it with the next link down in the chain it would then be UNDER the level of the head. What do you guys think? Should I align it under? Should it be fine where it is? Thanks for any help....
I forgot to mention this is at perfect TDC 1-4. I am more than happy to take the time to redo rather than foul it up.
1978 KZ1000 police
- jzanutto
The book says that timing mark must point right at the gasket line on top of the head
1978 KZ650B 2004 BMW R1150RT
- Bicycle Lee
1978 KZ1000 police
- keith1
- Thank you received: 2
my bike is a 78 KZ1000. I'm thinking just to be safe I'll redo it tomorrow. Any other opinions????
hey lee, are the cam holders tightened down yet? mine looked the same untill i cranked em down and then mark lined right up where it should be....i have the same motor......also i believe the book says to take up chain slack last after cams are in and everything is lined up and top sprocket is installed......just my .02.....keith
- Bicycle Lee
It was actually the other way around... The mark was lined up and after everything (including the cam chain tensioner) was torqued down, the mark was where it is now... The motor is at TDC and the cams are the right number of links apart, but the mark is maybe one link above where it should be. Is it everyone else's consensus that I should just take the 15 minutes it takes to take it off and move it??
1978 KZ1000 police
- keith1
might be a good idea....good luck
- DoubleDub
- Visitor
- modprod
So I assembled my motor today and I had a question about cam timing. I set the cams in, made sure all the slack was out of the cam chain, aligned the little > mark with the head and slipped it into the corresponding link in the cam chain.
Looks off about 2 teeth/pins on the ex. cam
- Bicycle Lee
1978 KZ1000 police
- modprod
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- timebomb33
I THINK MY POWERBAND BROKE
