cam timing question
- Bicycle Lee
I have a quick question though:
When I rotate the crank everything moves smooth and fine and then right when I'm passing TDC on 2-3 the chain gets a little slack in it. What could make this happen?
1978 KZ1000 police
- Thank you received: 2098
just reassembled it and got it to where I am comfortable with the result.
At TDC is when the rear side of camchain has the most slack, and is the position when the routine camchain adjuster maintenance setting should be performed.
Good Luck!
- Bicycle Lee
1978 KZ1000 police
- Bicycle Lee
IT FIRED
If the video turned out I'll post it
1978 KZ1000 police
- irishwill
- Thank you received: 6
- Bicycle Lee
although I'm getting a lot of smoke coming from the exhaust ports.
My head gasket seems to be leaking as well (which sucks cuz it's brand new).
It doesn't smell like burned oil, but I suppose it could be.
Is this to be expected when starting a motor for the first time? Does engine assembly lube make it smoke like that? Do new piston rings need some break in time and could that lead to a little oil in the exhaust??
any thoughts? Granted, I know the thing is 30 years old and a little leak is to be expected, but I'm wondering if there is anything else I should be looking for?
other than that it runs fine... starts right up, throttles nice... idles fine.
1978 KZ1000 police
- mark1122
- Keep twisting it
- Thank you received: 109
How did it run? what did u replace in the motor?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Bicycle Lee
So here's what's new in the motor: new rings (bore honed as well), new exhaust valves (the intake ones were fine), port work done on the head (Larry Cavanaugh did a great job) and new Andrews cams. I got new coils too.
The gasket is that two part gasket for the cylinder head and the oil is coming from the middle where the gasket doesn't cover it. I don't know if that helps the troubleshooting.
I DID give the inside of the cylinders a good amount of assembly lube so hopefully that is all it is... how long until I should start worrying about it?
If it were burning oil wouldn't it SMELL like it? Because it didn't really smell like burning oil... and the smoke was more gray and white than black. Maybe the fumes had gotten to me by then though.
1978 KZ1000 police
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- keith1
did u put the large o-ring in the block, between the 2 head gaskets?
man i hope he did....i was wondering the same thing....fingers crossed.....
- DoubleDub
- Visitor
www.z1enterprises.com/detail.aspx?ID=2717
Site between the two halves of the head gasket.
- Bicycle Lee
I also see that Z1 has a one piece copper gasket.... I might just have to get that.... I mean, the ones I have on there now are brand new and they're leaking... so maybe a one-piece is the way to go???
1978 KZ1000 police
