- Thank you received: 6
Engine seized up
- kawsakiman
Mr. Kawsakiman,
Were you able to find that crank just in case? Although i yet have to split the case(family issues kept me from working on the bike), what i can see and feel thru the crankcase cylinder bore, the no. 2 connecting rod is seized to the crankshaft. The others are free to move fwd n aft except rod no. 4 which feels a little sluggish. I'd like to find a local machinist that works on small motorcycle parts.
sorry eagle, i really have not been following this thread so much as i also have family issues.
but yes, i do have a crank and just about every other part you need to get on the road again.
i kind of knew it was in the lower end but was hoping for the best.
don't worry, we'll get you going again.
it's just locked up, no holes blown in your cases.
she can be rebuilt, we have the technology.
- eaglecrash2
'77 kz650,'06 Vulcan 500ltd, '07 ducati 1098s, '03 bmw m3, '85 carrera, '71 911s, '06 s2000, '03 suburban, '76 triumph TR6
sold: '69 honda 250, yr(?) 50cc honda moped, '52 Beechcraft Bonanza
Long Beach, California
- eaglecrash2
- eaglecrash2
- kawsakiman
if you promise to help another member, the cost will be next to next to nothing for you.
instead of paying me, how about you donate here so stein can keep this sight going?
( cost of shipping does not apply of course )
- eaglecrash2
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
Gringo, did you then replaced the 4 banger with the 750ltd engine? Did you do any mod?
This was just a straight up replacement, I had an 81 750 LTD here that had a crank with a messed up end from a previous owner's spill. This engine I used was from an 82 750 LTD so it was a direct swap, they both were 4 bangers. Other than changing the ignition and charging systems that same engine would drop right in your bike without any mods. Just something to think about since you would gain a few ponies by going to the 750.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
- eaglecrash2
- The Gringo
Let me get that straight. Yours was on a 81 750ltd, right? And you're saying a 750 engine will drop right in my 650 frame?
Correct, the only thing different is that the 750 LTD came with an electronic ignition and since you have a 77 650 the charging system on your bike is unique to that model year. To do things the easy way you would just swap over the ignition and charging system from your 650 to the 750 engine. The only mod I can think of you will have to make has to do with the dowel pins for the 650 dyno cover are different. This just requires a bit of drilling, no big deal.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- eaglecrash2
- The Gringo
Your stock exhaust will bolt up no problem as well because the 750 LTD used 6mm exhaust studs, IIRC the GPZ's used 8mm. I'd say parts availability would be about the same for both bikes. That's one of the things I like about the middleweight bikes, when it comes to finding parts they are like a small block Chevy.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- eaglecrash2
