Engine seized up
- eaglecrash2
'77 kz650,'06 Vulcan 500ltd, '07 ducati 1098s, '03 bmw m3, '85 carrera, '71 911s, '06 s2000, '03 suburban, '76 triumph TR6
sold: '69 honda 250, yr(?) 50cc honda moped, '52 Beechcraft Bonanza
Long Beach, California
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
- kawsakiman
- Thank you received: 6
blew the line at the bottom of the motor and it was too late to save anything.
the rod bearings were wiped out.
i would keep my eyes open for a lower half because i doubt it's in the top end.
at least that was my experiance.
good luck.
- bountyhunter
- Thank you received: 337
- mark1122
- Keep twisting it
- Thank you received: 109
OK BOYS how’s the best way for him to free the pistons?
U could try penetrating oil through the plug holes. come on guys i know u have better stuff than me . isn’t there a can of something just for this?
if that doesn’t work u could pull the head and hit the tops of the pistons with a wood block and hammer. didn’t someone just go through this here? Who was that. man I’m getting old.
:S
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Thank you received: 2829
- trianglelaguna
that mighta been me but no luck as it had been sitting a longggggggggggggggggggggg time ....as in.... me love you longgggggggggggggggggggggg time...but worse....Just for the hell of it i would try to free the piston refill with oil and try it. what do u have to loose. stranger things have happened.
:S
i agree about trying it before doing any thing hard(i'm lazy) re-fill it and bump start it, about four times , with the key off and a really good running start in third gear then.....try and start it...it may be no worse than the inside of some of our running bikes:woohoo:
1976 KZ900
2003 ZX12R
2007 FZ1000
- kzz1p
:S
Mark is it called anti-seize???? (just kidding)
- eaglecrash2
a complete teardown is what i gathered. Meanwhile I might look for a re-built depending what the cost is. Looks like this 650 will be shelved for a while. Man just when i had the ignition and fuel issues worked out. It's true that at least my son didn't crash. Back on the drawing board!
- gane
[img][/img] 1977 KZ1000A1
- kawsakiman
i'm almost sure i have a crank i can let you have.
i know i have cases.
sounds like a good time to go to www.kzzone.com
and buy a 700cc kit.
if you have to do it anyway, might as well go bigger and do it right.
plus they have added 650/750 cams to their lineup. good stuff!
sucks you have to do this now but man, i've been in your shoes before i heard of this sight.
no fear, just a little set back. we will walk you through it.
