Engine seized up
  • eaglecrash2
  • eaglecrash2's Avatar Topic Author
Re: Engine seized up
24 Mar 2009 13:03
#274922
Mr. Kawsakiman,
Were you able to find that crank just in case? Although i yet have to split the case(family issues kept me from working on the bike), what i can see and feel thru the crankcase cylinder bore, the no. 2 connecting rod is seized to the crankshaft. The others are free to move fwd n aft except rod no. 4 which feels a little sluggish. I'd like to find a local machinist that works on small motorcycle parts.
'77 kz650,'06 Vulcan 500ltd, '07 ducati 1098s, '03 bmw m3, '85 carrera, '71 911s, '06 s2000, '03 suburban, '76 triumph TR6
sold: '69 honda 250, yr(?) 50cc honda moped, '52 Beechcraft Bonanza
Long Beach, California
  • eaglecrash2
25 Mar 2009 09:59
#275273
Man i have problems: i cannot split the crankcase. all bolts/screws and accessories covers have been removed and the engine is off the frame but it just will not seperate! Any ideas???? Does the oil filter assembly has to come off as well to remove the oil pan? Help!!
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
25 Mar 2009 10:16
#275277
on a kz1000 u must remove the oil filter . it screws into the upper case throught the bottom case. and there are 3 bolt holes ,2 in the front & 1 in the rear that u use for jack bolts. u use the larger bolts from the case as jack bolts.
tripple check that u have EVERY SINGLE BOLT OUT FIRST.even the bolts on the top of the motor. some of them go into the bottom case.
Hope this helps.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • eaglecrash2
25 Mar 2009 10:23
#275280
Thanks Mark1122, i'll look it over again tonite. I can't help but noticed, where did you get the fender eliminator kit? Or did you fab it?
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
25 Mar 2009 17:40 - 25 Mar 2009 17:58
#275369
I've been watching this post and hoping for the best for your engine.
It's easy to eliminate your fender by just taking off the stock one, and using a couple brackets to mount your stock light or one off another bike. Then fab up a license plate holder off the rear most frame mounts.
First time around with the stock light, I used a piece of plastc to fill where the fender was removed.
Second time around with a ZX6E tail light, I used a second stock plastic inner fender cut short to fill in where the stock chrome fender fits:
Second time around:
Second inner plastic fender cut short, then trimmed after fitting light:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 25 Mar 2009 17:58 by rstnick.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
25 Mar 2009 18:27 - 25 Mar 2009 18:44
#275386
I actualy looks better from a distance. i did a bit of a test hack job on it .but it works for now.i would like to make it a little longer so i dont throw as much mud up on my lt. i will do it again . i have a zx12 lt imay use as well?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 25 Mar 2009 18:44 by mark1122.
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
25 Mar 2009 18:51 - 25 Mar 2009 19:04
#275403
here is what i did.
i carved up the rear fender. i attached the tail light directly to the bottom of the tail piece. then i bolted the lic. Plate to the fender piece. What a mess. but it is a progression.
Previously i had the plate attached to the lt with a bracket and no fender. i'm still thinking up plan d.:laugh:
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 25 Mar 2009 19:04 by mark1122.
  • eaglecrash2
25 Mar 2009 20:32
#275447
Thanks for the pics. I like it. While waiting for my engine parts I'm going to start the mods. Yes I got the crankcase apart and the crankshaft is shot. Nos 2 and 4 connecting rod journals are all scarfed up. In fact the rod bearing is still "welded" to the journal on no. 2. I definitely need another crankshaft.
  • eaglecrash2
26 Mar 2009 11:08
#275529
Folks, I'd found an outfit that specializes on motorcycle crankshafts. They can weld and nitrite the damaged journals for me and re-heatreat.Takes about 2 weeks. For cheaper costs, I was advise to find undersized bearings.
  • BSKZ650
  • BSKZ650's Avatar
26 Mar 2009 12:49
#275556
I am not so sure on the welding up the crank, dollar wise I think it could be replaced for a lot less money, I do have a 78 engine that the top end was ruined, due to water, I think the bottom end is still in good shape, if you want I can check it to see,,let me know
77 ltd1000, current rider
76 kz900, just waiting
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
26 Mar 2009 13:45
#275568
I'd have to second that, just to buy the new bearings if you can find them would be more than you should be able to get a used engine for. Start combing your local Craigs list for a parts bike either a 650 or a 750. I know that kind of stuff is out there I bought a 750 LTD engine off ebay locally with 18K on it for $40.00 the only thing wrong with it was they had it over filled with oil so it smoked. I changed the oil in it and now it runs fine and doesn't smoke a bit.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • littlemanonbigbike
  • littlemanonbigbike's Avatar
26 Mar 2009 14:40
#275581
Came across this on ebay 350157353388. Just wonder though, what caused the crank and rods to fail?
1982 1100 Spectre
Various other toys
