- Thank you received: 1
KZ1000 Miss at 3800 RPM
- Russ Jackson
03 Mar 2009 06:51 #269393
by Russ Jackson
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
Replied by Russ Jackson on topic KZ1000 Miss at 3800 RPM
Sure you can put the pick-up on any plug wire. I still think it is carb related. But we will see....Russ
- Hogslayer
- PUFF DADDY
03 Mar 2009 09:48 #269417
by Hogslayer
Replied by Hogslayer on topic KZ1000 Miss at 3800 RPM
Here is a quick way to make sure the intakes are sealed up and not leaking. Spray starting flood around each intake manifold and if the RPM increases your intakes are leaking which would affect your fuel mixture.
- grumpy56
- Thank you received: 6
04 Mar 2009 19:24 #269740
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
Replied by grumpy56 on topic KZ1000 Miss at 3800 RPM
Evening fellas. Problem solved. Put my timing light on plug wires 2 and 3 and no light at 4K RPM. On wires 1 and 4 it was fine. Unbolted the 2/3 coil and wouldn't you know, one of the 2 wires fell out of the connector holding it to the coil. Put a new terminal on it, warmed er up, and presto, runs perfect.
Thanks to all of you for your help.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- MFolks
- Thank you received: 540
04 Mar 2009 19:56 #269745
by MFolks
Replied by MFolks on topic KZ1000 Miss at 3800 RPM
Sometimes it's the simple things we forget.
- trianglelaguna
- Thank you received: 235
04 Mar 2009 20:03 #269749
by trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Replied by trianglelaguna on topic KZ1000 Miss at 3800 RPM
i was thinking that but you never know when give a tip if your gonna lead some one away from the real problem...or to a solution.....we excpect pictures now.....ride on and enjoy...craig
1976 KZ900
2003 ZX12R
2007 FZ1000
- gane
04 Mar 2009 20:38 #269756
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic KZ1000 Miss at 3800 RPM
Grumpy, Nice. on a different topic, on whim scanned tool kits and their repective components. It's been a week or two so have forgotten particulars, but Kaw P/N 56007-1021 seems to be pretty close to orig. kit.retails' for @$70.00. I reserve my "anoyance" factor w/ parts personell for my projects, but you might persue if intrested. luck G
- grumpy56
05 Mar 2009 05:23 #269795
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
Thanks guys and I will check out that tool kit.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- keith1
05 Mar 2009 18:24 #269900
by keith1
Replied by keith1 on topic KZ1000 Miss at 3800 RPM
glad ya found it.......
