- Thank you received: 6
KZ1000 Miss at 3800 RPM
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- keith1
- Thank you received: 2
continuing on....checked the timing with a strobe light and the advancer is working fine. The fault tree in the KHI Manual seems to infer there is a coil issue if you have spark and the advancer is working. Any thoughts on that? Assuming this is an electrical problem also.
could be a coil issue, but i dont get how it would clear up in upper rpmS....battery good? a bad coil is bad all the way through i would think..assuming shim job is good, i keep thinking fuel.....when it stumbles, what comes out exhaust?
i would guess if its a coil prob, you should be spitting a little black out the pipe...gas smell?
just trying to help...keep us posted.....
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- keith1
thank you guys...i will run one of the tests in the manual to kind of check the coils and also ensure all the wires are connected properly...the only funy thing i noticed when i changed the plug wires was all this "dust" (fried connector I think) that emptied out of the coils..don't think that is healthy, but as ketih mentions, everything coming back loud and clear when really revved is weird...will keep you guys posted
check your battery....see what ya get across terminals with bike off, get it running and if ya can get it up to around 4k , read across batt again with headlite off....you can get a cheapy digital multi-meter...harbor freight has one for like 5 bucks...i just grabbed one to replace my sunpro that crapped out...i was using a wally mart special, but its tough to tell where ya are
with the way the numbers are set up on face...good for ballpark...keep us posted....
- trianglelaguna
the wire could still get a jumping spark to fire sometimes but was an inch out of the coil......yours may be somthing totaly dif but sounds like what i found to be a coil not firing right.....any lttle info the guys gave me helped..... food for thought....craig
1976 KZ900
2003 ZX12R
2007 FZ1000
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
- Thank you received: 2098
Would assure clean tight terminal cable connections, and good ground connection where negative battery terminal attaches to engine/frame.
With known good fully charged battery and tight terminal connections and ground connection, as keith1 suggested, would measure voltage across battery terminals at low idle (look for 12-13 volts) and at 3000-4000 rpm (look for 14-15 volts). This will help determine condition of charging system and functioning of regulator and rectifier.
Then measure positive voltage actually reaching each coil primary winding, which should be equal to or almost same as voltage measured across battery terminals.
Good Luck!
- grumpy56
The first thing I did was to replace the battery since I knew the old one was tired. Didn't help. Also, the timing light fires as expected even when the engine is sputtering. I had the pickup on cylinder # 1. Could I use the timing gun to check for juice at my problem RPM area by attaching the pickup to each cylinder and seeing what happens?
Airbox is clear and the miss appears to be rev dependent, not throttle position, so that would lead me to think it is an electrical issue. Will measure the coils tonight and see what I get.
Boy, haven't had this much fun since I spotted some attractive honeys on the Daytona Beach back in 1976, decided to give the old Z-1 a bit of throttle, and zzzzrrrrreeeeeewwwww...Z and me on the sand! Memorable moment.
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
