- Thank you received: 6
KZ1000 Miss at 3800 RPM
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
Adjusted my valves and buttoned everything up. Started fine and below about 3800 rpm everything is fine. But at about that point, it feels like I am losing 2 cylinders and it barely runs (and doesn't gain rpm). Swapped out my plug wires since they weren't too good. but didn't help. Was going to change the plugs next. Any thoughts/guidance is appreciated. Thank you!
How did it run before you adjusted the valves? Did you recheck evrything that you touched?
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- keith1
- Thank you received: 2
- trianglelaguna
- Thank you received: 235
..the odds that something went south electrical at exactly the same time you did valve adjustment seem pretty long to me....i know you are not a rookie, but i would go back in and recheck...we all make mistakes..i did a valve adj once and bike wouldnt start..check for spark nada..the red wire for dyna came undone wrestling h-cover back on...quite the shotgun blast when i hit the button with fueled up cylinders...:laugh: ..just my .02....keith
yeah somthing like that i was thinking and asking questions and finally i took my harness all the way off one zip tie at a time and found where my problem was this time (dif all the time...lol)you got somthing unplugged or just barley plugged in is my 2 cents...i just had a close deal on mine....good luck,,,mine was a coil/plug wire that worked loose and was jumping the spark and sputtering...this time:laugh:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- MFolks
- Thank you received: 540
- kzz1p
You might think about checking the wires under the gas tank. It is easy to bump something while taking the tank off and on.
- Thank you received: 2098
...Swapped out my plug wires since they weren't too good. but didn't help....
What type plug wires, caps, and ignition coils are presently fitted? (Am thinking oem coils had permanently embedded plug wires). Perhaps a faulty component and/or faulty connection, such as, coil>plug-wire, plug-wire>cap, and/or cap>plug.
What type of ignition is presently fitted? (oem with igniter; Dyna-S; something else) ?
Has ohm reading been done on coil circuits, both primary and secondary?
With engine running in dark area (eg., unlighted garage at night), could spray water mist (use common hand-held household spray bottle) all over top area of engine (coils, plug wiring, caps and plugs) to determine whether there's leakage in the hign tension circuit (look for arcing sparks).
What is measured positive battery voltage at coil primaries with engine off and ignition switch in ON position? (Thinking possibly insufficient voltage to coils for whatever reason).
While changing to brand new spark plugs, would visually inspect spark quality on each new plug before installing it.
Good Luck!
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- keith1
