deep oil pan?
- kano
- Not Another Bloody Limey!
- kano
- kano
- kano
- kano
- kano
- kano
- kano
- kano
- kano
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
while i wait for my wheel to come back i decided to look at my engine, last time i worked on it was 92 ish.
when i chipped a valve and had to replace the valve sleeve and piston any way getting off track a bit sorry.
so i remove sump to try on the deep sump i bought 4 mths ago,it came with a modified oil pump with a pipe extending down to the lowest point.
now when i hold up the new pump the oil pipe hits a small web which doesn't seem to be any use now with the new sump,
so the question is anyone heard of problems with grinding out the web so everything bolts up properly.
plus any idea who made this pan?
Dam I can't remember who made the pan. Are you using it a street bike? It will not hurt to grind the case right there.
- kzz1p
That's a nice looking pan. I have one very similar, but mine was made here locally. I'll try to post a picture of the inside - mine might have been modified like your asking but I'm not sure.
This picture doesn't help - let me look for a better picture...
Was that one of the deep pans that had little to done, oil pressure at an Idle or low speed???
