deep oil pan?
  • kano
  • Topic Author
  • Not Another Bloody Limey!
21 Feb 2009 19:32 #266929 by kano
deep oil pan? was created by kano
while i wait for my wheel to come back i decided to look at my engine, last time i worked on it was 92 ish.
when i chipped a valve and had to replace the valve sleeve and piston any way getting off track a bit sorry.
so i remove sump to try on the deep sump i bought 4 mths ago,it came with a modified oil pump with a pipe extending down to the lowest point.
now when i hold up the new pump the oil pipe hits a small web which doesn't seem to be any use now with the new sump,
so the question is anyone heard of problems with grinding out the web so everything bolts up properly.
plus any idea who made this pan?
21 Feb 2009 19:55 #266933 by timebomb33
Replied by timebomb33 on topic deep oil pan?
can you send a picture of the area that your talking about just so that it is clear in everybodies mind by the way you knew the picture thing was coming didn't you
I THINK MY POWERBAND BROKE
21 Feb 2009 20:05 #266937 by 79MKII
Replied by 79MKII on topic deep oil pan?
That's a nice looking pan. I have one very similar, but mine was made here locally. I'll try to post a picture of the inside - mine might have been modified like your asking but I'm not sure.
This picture doesn't help - let me look for a better picture...
The Kaw List:
  • kano
  • Topic Author
21 Feb 2009 20:07 #266939 by kano
Replied by kano on topic deep oil pan?
yeah i did lol.
ill take the camera tomorrow.
and plenty of pic's plus i want to show you guys what i found in the sump.
i have no idea what it is but it inch by 1/4 piece of metal about 1/16 gauge forgot to bring it home to show you guys.
21 Feb 2009 20:11 #266943 by 79MKII
OK, found a better picture. Do you mean the baffles (red arrow)? If so, no problem to remove those.
The Kaw List:
21 Feb 2009 20:13 #266944 by 79MKII
I just happened to think - are you talking about the engine that needs clearanced or the pan??:S I can get a little confused sometimes!:laugh:
The Kaw List:
  • kano
  • Topic Author
21 Feb 2009 20:17 #266946 by kano
that's exactly where the web is not in the sump in the lower case i seems to be where the fins are where ppl used to put a gate to slow down oil on fast accelerating.
21 Feb 2009 20:22 #266951 by timebomb33
that is excactly what those are for wich is no big problem since you now hace a rear mounted sump
  • kano
  • Topic Author
21 Feb 2009 20:24 - 21 Feb 2009 20:36 #266953 by kano
like to check before i brake out the grinder lol.
ill still take some snaps for the record.
thx guys;)
any idea who made it Egli?
Last edit: 21 Feb 2009 20:36 by kano.
21 Feb 2009 20:28 #266956 by timebomb33
good idea measure twice and cut once or was measure once and cut twice i allways get confused
21 Feb 2009 20:56 - 21 Feb 2009 20:58 #266967 by 79MKII
So it's actually hitting on the engine side?
I can't remember if my cases were modified or not, but the pan had the baffles removed for sure.
The Kaw List:
Last edit: 21 Feb 2009 20:58 by 79MKII.
21 Feb 2009 21:02 #266968 by 79MKII
OK, found a picture of my engine with a normal oil pump. Does yours look like this?
The Kaw List:
