- Thank you received: 10
valve stem seal installation
- timebomb33
I THINK MY POWERBAND BROKE
- jzanutto
I am going to lap the valves first
1978 KZ650B 2004 BMW R1150RT
- timebomb33
- PLUMMEN
- Thank you received: 104
- Thank you received: 2098
please don't lap the valves all it does is widen out the valve seat and make the contact area wider.
Amen. With today's seat cutting and valve facing techniques, isn't old fashion valve grinding compound obsolete, along with the handle-fitted suction cups?
- PLUMMEN
- Link14
- Thank you received: 6
- PLUMMEN
Valve Lapping
- SPARKY47
- 1980 KZ500 B2
- Thank you received: 5
Thing is this, new oem valves,guides,springs.
The bits for this baby cost more arms than I've got so I can't risk a mistake like this.
So with so many opinions what to do?
I aint tossing no coin.
1980 KZ500 B2
- timebomb33
PLUMMEN wrote:
within a couple minutes of warming up that little bit of surfacing is lost due to expansion anyway,i can understand it maybe after a fresh valve job just to make it perfect.but by itself i see no benefit.
This seems consistent with the FSM (at least from 1973 through 1979) because the FSM does include lapping (first using coarse, then fine grinding compound) after the valve faces and seats have been freshly cut to specs "to properly match the surfaces."
I find nothing in the FSM to suggest that lapping would be appropriate thereafter under any other circumstances (such as additional lapping later on whenever it might be convenient).
As known, the width of the mating surface between valve and seat is critical to the balance of proper sealing and heat transfer.
I believe timebomb's excellent advice is directed against random additional future lapping likely to widen the mating surfaces beyond specs.
My lesson learned -- lap only incident to fresh cutting.
Good Luck!
