valve stem seal installation
- jzanutto
do you put anything on the guide to lube it to help the new seal go over?
1978 KZ650B 2004 BMW R1150RT
- PLUMMEN
- Thank you received: 104
- Sandy
- Fly High,Tony
- Thank you received: 13
Don't remove it...don't have to.
1977 KZ1000 A-1
- PLUMMEN
- Sandy
- Fly High,Tony
5/16 nut driver works good for install tool :laugh:
And all this time,I've been using my mouth!:blink:
1977 KZ1000 A-1
- jzanutto
- PLUMMEN
somethings are just better left unknown! :ohmy: :huh: :dry: :blink: :blush: :S :woohoo:PLUMMEN wrote:
- Old Man Rock
- Thank you received: 225
hahahahahahaha
OMR, leave this one alone, don't go there, run away, keep thy smart ass mouth shut etc.... :laugh: :laugh:
Boy, talk about an opening line to attack... Plummen must be peeing himself with delight on that one! :lol:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Mcdroid
- Gone Kwackers
- Thank you received: 317
when putting the new valve stem seals in, do you guys put the little clip on the seal and push it on, or do you put the seal on first and then push the clip over the seal?
I am confused...what 'clip' are you referring to? I see no 'clip' on the exploded diagrams on www.kawasaki.com
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Jeff.Saunders
One thing to check - make sure there are no burrs on the stem of the valve. Often the tops can be razor sharp.
www.z1enterprises.com
Z1 Ent on Facebook,
- jzanutto
- Jeff.Saunders
Jeff, I bought my gasket set from you - are there new clips on the new seals?
Yes...
Z1 Ent on Facebook,
