valve stem seal installation
  • jzanutto
  • jzanutto's Avatar Topic Author
27 Jan 2009 19:27
#260556
when putting the new valve stem seals in, do you guys put the little clip on the seal and push it on, or do you put the seal on first and then push the clip over the seal?
do you put anything on the guide to lube it to help the new seal go over?
1978 KZ650B 2004 BMW R1150RT
  • PLUMMEN
  • PLUMMEN's Avatar
Re: valve stem seal installation
27 Jan 2009 19:31
#260558
a little lithium grease
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
27 Jan 2009 19:52
#260563
Leave the clip ON the seal!
Don't remove it...don't have to.B)
1977 KZ1000 A-1
  • PLUMMEN
  • PLUMMEN's Avatar
27 Jan 2009 20:23
#260569
5/16 nut driver works good for install tool :laugh:
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
27 Jan 2009 20:31
#260571
And all this time,I've been using my mouth!:blink:
1977 KZ1000 A-1
  • jzanutto
27 Jan 2009 21:45
#260579
I dont know if I saw new clips on the new seals... the garter springs are on top, but didnt see any clips
  • PLUMMEN
  • PLUMMEN's Avatar
28 Jan 2009 05:35
#260610
somethings are just better left unknown!:unsure: :ohmy: :huh: :dry: :blink: :blush: :S :woohoo:
  • Old Man Rock
  • Old Man Rock's Avatar
28 Jan 2009 07:04 - 28 Jan 2009 07:05
#260620
hahahahahahaha
OMR, leave this one alone, don't go there, run away, keep thy smart ass mouth shut etc.... :laugh: :laugh:
Boy, talk about an opening line to attack... Plummen must be peeing himself with delight on that one! :lol:
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 28 Jan 2009 07:05 by Old Man Rock.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
28 Jan 2009 07:21
#260625
I am confused...what 'clip' are you referring to? I see no 'clip' on the exploded diagrams on www.kawasaki.com
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
28 Jan 2009 08:26
#260636
The valve stem seals do have a wire clip around the outside to help hold them in place. Never remove them.
One thing to check - make sure there are no burrs on the stem of the valve. Often the tops can be razor sharp.
  • jzanutto
28 Jan 2009 08:42
#260638
Jeff, I bought my gasket set from you - are there new clips on the new seals?
  • Jeff.Saunders
  • Vendor
  • Vendor
28 Jan 2009 10:19
#260665
Yes...
