bottom end
- jzanutto
my other issue is there are 2 bearings stuck in the side of the upper case half and they wont come out. One is the big ball bearing for the one end of the starter shaft, the other is a big roller bearing which I think goes to the end of the shift drum.
anyone got any tips on getting those out? I dont think they should be stuck like that
1978 KZ650B 2004 BMW R1150RT
- jzanutto
- jzanutto
- PLUMMEN
- Thank you received: 104
- kawsakiman
- Thank you received: 6
just on my experiance, i have reused MANY main Bearings in smaller cc motors with no ill effects.
if you find someone who sells factory correct bearings, please let me know.
plasticgauge has always been in spec for me.
the smaller one's have a problum with the starter clutch, but other then that, i find them rather bulletproof.
i beat the sh#t out of mine and the brother in laws all the time.
if the plasticgauge shows it in spec, i say run with it.
- jzanutto
- shighley
I'll be doing this soon I hope. As I understand it, the common choices for blasting media are silica sand, sand, crushed glass and glass beads (ton of others). Which did you use and what is the catalyzed clear, manufacturer, etc. I've use Dupont 780S before and it held up extremely well. The only thing is that it darkened the bright glass beaded surface somewhat. Small tradeoff for the corrosion resistance and sealing properties. I'm after the "factory new" finish that came on the castings (with zero maintaintence afterwards) I'd like to experiment with using steel shot or walnut shell before I actually decide on the process. Thanks for the pictures and keep 'em coming. Ride safe, Steveso I chose natural finish, but I did put a clearcoat on as a sealer so it will be easy to keep clean. Its a 2 part catalyzed clear
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
- timebomb33
I THINK MY POWERBAND BROKE
- jzanutto
We have glass beads at work, and we also have a plastic media blaster. The glass beads on aluminum is a little brighter than original but is sure is clean and uniform looking. I pressure wash out all the passages, then I use pipe cleaners with a little bit of sticky grease on them and run them through the passages to pick up anything that might be missed. THen once more with a clean pipe cleaner to remove any greasy residue. Never had any problems with doing it that way.
I think that if a person is anything less than 100% meticulous you would then run a risk of leaving some residue behind
- jzanutto
- timebomb33
