- Thank you received: 104
bottom end
- PLUMMEN
- jzanutto
I clean the oil passages with pipe cleaners.
1978 KZ650B 2004 BMW R1150RT
- dman3998
all my 2 strokers have the segmented crank with ball bearings. To me plain bearings seem to be a step backwards. I know it eliminates having special crank tooling and a special service manual just for the freekin crank, but anyone care to make some intelligent comments here about why plain bearings?
Journal bearings handle much more power than ball bearings. with a pressurized film of oil, in theory the surfaces dont actually touch, with a roller or ball there is contact all the time and a very focused point of contact.
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
www.buykawasaki.com is a great parts availability website, and can tell you if the parts you need are "Active", "Active Limited Quantity", or "Cancelled". Most internal roller bearings can be purchased at a bearing house to save you some money.
Not to steal your thread, but I am doing a complete tear down, "just 'cuz" on one of my spare GPz550 engines, I plan on installing the best of my aftermarket goodies including the 615cc kit I've had all ready for 2 years now. I'm wondering about the crank and rod bearing "shells". There are 3 sizes of crank bearings and rod bearings available from Kawasaki. After I emory-cloth polish the crank and rod journals, what's the recommended clearance for oil? Should I just go with what the Kawasaki Factory Manual suggests for oil clearance on both rod and crank bearings of .004" or 0.10mm, or is there some other magic number?
Keep us posted on your build up.
'85 GPz550(ZX550-A2)
- BSKZ650
- Thank you received: 14
Babbit bearings have been around a long time, and have been tried under the most extreame conditions.
The roller bearing engines are a lot more complicated to set up and that would add a lot of expense to the engine mfg process.
Unless something is really worng with the bottom end. a good cleaning and careful reassembly will produce an engine that will last for a lot of years
77 ltd1000, current rider
76 kz900, just waiting
- CoreyClough
- GPz550 Addiction
- hugo
- '92 Zephyr 750
- Thank you received: 71
Yes, I remember in Engineering school going thru this. In theory, as the crankshaft rotates squeezes the oil film that becomes superstrong, not allowing the metal surfaces to touch. The faster it turns, the stronger the oil film. As you said before, in theory, there should not be metal to metal contact during rotation. The wear could only occur during the first turns of the crank, when engine is started, as there may be little oil and pump is just awakening. I believe all cars use also plain bearings.
I used to work in a power plant with big steam turbines, and the turbines rotors rode in huge plain bearings. Before starting the turbines, an electric oil pump would be started to pump oil inside the plain bearings before allowing the turbine to turn. If we had electric oil pumps in cars and motorcycles, started a couple of minutes before cranking, our bottom ends(engines) would last for ever.
- CoreyClough
- GPz550 Addiction
- jzanutto
- bountyhunter
- Thank you received: 337
[If we had electric oil pumps in cars and motorcycles, started a couple of minutes before cranking, our bottom ends(engines) would last for ever.
They used to sell aftermarket ones for turbo engines in cars. The turbos would fail VERY early in life from city driving because at turn off, the oil flow stops and the heat in the turbine's bearings would boil the oil there. Then when you start it, the bearings were dry. I remember electric "pre" and "after" oilers that would keep oil flowing a while after the engine turns off and pump it up before you start it.
- CoreyClough
- GPz550 Addiction
- jzanutto
