bottom end
- jzanutto
So once I pull the crank, even if the bearings look good should I plastigauge them and see how much clearance there is?? Rods get plasti too right??
all my 2 strokers have the segmented crank with ball bearings. To me plain bearings seem to be a step backwards. I know it eliminates having special crank tooling and a special service manual just for the freekin crank, but anyone care to make some intelligent comments here about why plain bearings?
1978 KZ650B 2004 BMW R1150RT
- PLUMMEN
- Thank you received: 104
- trianglelaguna
- Thank you received: 235
so I've got the top end of this thing off, (78 KZ650B) the cams dont look like they have much wear at all. Valves are .003 - .004. So now I am going to pull the bottom end to look at it. (why, cuz I just bought this and want to see exactly what I have, and it needs a starter clutch anyway)
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Becker
- The Doctor Will Rise Again
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- jzanutto
also, does that big mesh drive chain wear at all?
- PLUMMEN
- jzanutto
- arai59
- Banned
- Thank you received: 2829
- bountyhunter
- Thank you received: 337
I would. New bearings would be really easy to install while it's open.well should I plastigauge while its apart?? I have to lift the crank out to get the new timing chain in anyway.
jzanutto wrote:
It shouldn't wear much. I think it's swimming in oil when it runs.also, does that big mesh drive chain wear at all?
- jzanutto
- jzanutto
