- Thank you received: 104
bottom end
- PLUMMEN
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
'85 GPz550(ZX550-A2)
- jzanutto
1978 KZ650B 2004 BMW R1150RT
- PLUMMEN
- jzanutto
- H2RICK
- Is this a fun bike, or what!!!
Here are additional reasons manufacturers like to use to plain bearing cranks:
1) they are cheaper to manufacture because they can be mostly finished in NC machining equipment and require NO expensive hand labour to assemble them.
2) plain bearings can handle FARRRR more dirt in the oil than ball/roller bearing cranks. Ball/roller bearing cranks fail quite quickly (relatively speaking) if their oil is not changed religiously. This means that for the average owner who is NOT into spending time/money on proper maintenance the plain bearing crank is the way to go.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- Old Man Rock
- Thank you received: 225
Friggin aye, it's every where... :S
Very cool image for I have never seen the 650 lower end apart so now I understand in other postings where they were speaking of regarding main drive chain... I was like huh.... Now I know....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- PLUMMEN
yeah some people are natural born idiots,there should be a competancy(spell check) test given before you can buy a tube of silicone!:laugh:Wholly Crapola... Did the PO use (go over board) some gasket making material or what.... :blink: RTV???
OMR
- jzanutto
- jzanutto
- jzanutto
- shighley
I've another question on the primary chain. When we did the motor on my son's 650, the chain seemed like it had too much play. The FSM said 27mm allowable slack and we were in tolerance. The thing is noisy at idle even with spot on carb sync. My question is how much slack in present when a brand new chain is installed?
Keep the pictures coming! Ride safe, Steve
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
