- Thank you received: 10
MTC-piston clearence question
- timebomb33
11 Nov 2008 17:18 #246910
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic MTC-piston clearence question
like isaid in my other post i use copper coat spray if im planning on removing the block from time to time but i use gasgasicinch if i plan on have the block on for extended periods like on a street motor. it seems to work best.
- APE Jay
- Banned
- Thank you received: 58
12 Nov 2008 08:39 - 12 Nov 2008 08:39 #247042
by APE Jay
Replied by APE Jay on topic MTC-piston clearence question
Don't use a copper head gasket unless you have so much compression or boost that you have to run an o'ringed block.
Here are your gaskets
Jay
Jay
Last edit: 12 Nov 2008 08:39 by APE Jay.
- mark1122
- Keep twisting it
- Thank you received: 109
12 Nov 2008 17:03 #247113
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic MTC-piston clearence question
Thanks Jay.
I was just wondering about the .040" shim u would use to shim a block if u are useing j pistons. Would u use a fiber gasket under that ? what would u use for sealers?
That would be a similar situation that i have with my block, sinse my block has been decked .030" and it needs a .030"shim to lower compresion. Or a thicker .050"fiber,wich may pound out?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
