MTC-piston clearence question
19 Oct 2008 12:59 #242662 by no name
MTC-piston clearence question was created by no name
I have a question about MTC piston to cylinder clearence.
MTC says the clearence for street pistons (10,5:1) is only
0.0005 to 0.01 ".
This is only 0.0127 to 0.025 mm (I´m from Germany ;) ),Kawasaki pistons have 0.04 to 0.07 mm.
Are the MTC clearence specifications really correct ?
19 Oct 2008 13:49 #242670 by timebomb33
Replied by timebomb33 on topic MTC-piston clearence question
the mtc pistons are incredible,the alloy's they use in their pistons expand at roughly the same rate as the cylinder, that is why they can run their clearances so tight. the first set of mtc pistons i put in years ago told me the clearances i thought it was a misprint, so i called mtc up the next day to double check and those were the right clearances.i was so used to stock cast pistons or wiseco forged with quite a bit looser clearances it was quite a shock to see some that were so tight. one note of warning as they are so tight be very careful installing them in the block.
I THINK MY POWERBAND BROKE
22 Oct 2008 06:53 - 22 Oct 2008 06:53 #243202 by JDScherz
Replied by JDScherz on topic MTC-piston clearence question
Good Luck..I own the very same pistons. And 3 exhaust valves and 1 Intake valve later and 2 base gaskets(stacked) and after sending them back to MTC and paying them 150 to remachine them down they are GREAT!? I know prostock bikes use them...but we are not prostock bikes, we are looking for reliability on the steet. Use them as ashtrays and buy WISECO! Just a thought...
Last edit: 22 Oct 2008 06:53 by JDScherz.
22 Oct 2008 20:51 #243319 by timebomb33
had your block been decked.
23 Oct 2008 01:13 #243339 by PLUMMEN
Replied by PLUMMEN on topic MTC-piston clearence question
did you check the deck height before final assembly of motor?how about valve to piston clearance?theres more involved to engine building than just bolting a bunch of parts together B)
23 Oct 2008 17:38 #243437 by steell
Replied by steell on topic MTC-piston clearence question
Anyone that runs with .0005" piston to cylinder clearance has a lot bigger balls than I do :woohoo:
23 Oct 2008 17:54 #243441 by 77_650B1
Replied by 77_650B1 on topic MTC-piston clearence question
Big ol balls. :ohmy:
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
23 Oct 2008 20:01 #243459 by gane
Replied by gane on topic MTC-piston clearence question
Perhaps we're comparing apples to oranges. .002-.004 inches is pretty typical piston to cyl tolerance. and allowing for advances in metalurgy, half that is understandable. valve to piston clearances however haven't changed that much.in the day, race motors (decked heads/surfaced cyls/big valves/stroked cranks/hi-comp. pistons/high lift cams, etal,)usually came with the recommedation of @ .020 inches clearance for valve to piston. (checked by assembing with lead or clay attop piston, rotating crank, dissassembly and measuring squished remains)... signs of insufficient piston to cyl clearances would be siezure, broken rings, broken piston lands. whereas kissing valves could easily be the product of worn rods/crank/rod bearings/insufficient clearance/high revs, again etall. especially in the case of 30 year old roller cranks. just points to ponder,G
[img][/img] 1977 KZ1000A1
24 Oct 2008 05:57 #243500 by shighley
Replied by shighley on topic MTC-piston clearence question
Is it possible the MTC pistons are cast and the Wiesco are forged, thus explaining the difference in clearance requirements? Seems I remember that forged ones required more clearance as they swell more coming up to temperature. Something about the material grain structure inherent to both processes. On the other hand I could be full of schiet. Happy Friday and ride safe, Steve
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
24 Oct 2008 06:19 #243506 by BSKZ650
Replied by BSKZ650 on topic MTC-piston clearence question
if you run .0005 clearance, I think you are going to gauld the piston real fast, .002-.004 sounds more like what it should be, dont forget to check the ring end gap
77 ltd1000, current rider
76 kz900, just waiting
24 Oct 2008 09:26 #243540 by APE Jay
Replied by APE Jay on topic MTC-piston clearence question
MTCs are forged and are a very good piston. We are an MTC distributor.
Jay
24 Oct 2008 09:39 #243542 by 77_650B1
Since Jay says they're forged, we'll take his word, he's the man. But I'll add my $.02. You're right about microstructure. Maybe MTC uses a different alloy with a different thermal expansion coefficient, or a different heat treatment with the same results. They wanted tight clearances, and engineers can do this. I'm sure I could with a but of time, a materials lab like the one at my school, and the Aluminum volume of the Metals Handbook. And as for galling the piston, I would venture to say that smaller clearance would reduce it, not increase it. Greater moment arm for galling against the cylinder wall if you have more clearance.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
