MTC-piston clearence question
- no name
- steell
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- JDScherz
- gane
[img][/img] 1977 KZ1000A1
- APE Jay
- Banned
- Thank you received: 58
Jd, Idle thoughts. 1st, unless oversize valves,bent valves,or piston slop, valves should nevet contact cut-outs.regardless of head/cyl shaving... valve contact to base of piston relief can be high lift cam, worn rod/crank,bearings,cam timing,incorrect pistons.having nothing to do with piston to cyl clearances.G
When you mill the head, you move the valves to the outside in relation to the piston. Valves can contact edge of the pockets.
- mark1122
- Keep twisting it
- Thank you received: 109
JD, When u added the extra copper base gasket to gain clearance what did u use for glue? did u have leaks?
i have a block that has been deck, and wondered wether a shim gasket would leak?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- APE Jay
- Banned
Copper Coat on the base gaskets.
Jay
- mark1122
- Keep twisting it
What would be less leak prone? 1 thicker copper base gasket or a fiber plus a thin copper base gasket as a shim.(for the street.)and useing a fiber head gasket.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- timebomb33
- mark1122
- Keep twisting it
I didnt know cometic would make a thicker gasket. i thought a thicker fiber would be more likely to sqeeze out. The fiber base gasket i have in now is trying to sqeeze out. i used ebond 1194 on it.
last year i had copper head and base, with Copper kote and it leaked.
I'm just getting all my options out . right now i would rather start over with a new block ,but if i could get a thicker base gasket ? The old block was decked about .025".
I think it would make too much compresion for pump gas?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- JDScherz
