MTC-piston clearence question
- no name
MTC says the clearence for street pistons (10,5:1) is only
0.0005 to 0.01 ".
This is only 0.0127 to 0.025 mm (I´m from Germany ),Kawasaki pistons have 0.04 to 0.07 mm.
Are the MTC clearence specifications really correct ?
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- JDScherz
- timebomb33
- PLUMMEN
- Thank you received: 104
did you check the deck height before final assembly of motor?how about valve to piston clearance?theres more involved to engine building than just bolting a bunch of parts togetherGood Luck..I own the very same pistons. And 3 exhaust valves and 1 Intake valve later and 2 base gaskets(stacked) and after sending them back to MTC and paying them 150 to remachine them down they are GREAT!? I know prostock bikes use them...but we are not prostock bikes, we are looking for reliability on the steet. Use them as ashtrays and buy WISECO! Just a thought...
- steell
- 77_650B1
Anyone that runs with .0005" piston to cylinder clearance has a lot bigger balls than I do :woohoo:
Big ol balls. :ohmy:
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- gane
[img][/img] 1977 KZ1000A1
- shighley
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- APE Jay
- Banned
- Thank you received: 58
Jay
- 77_650B1
Is it possible the MTC pistons are cast and the Wiesco are forged, thus explaining the difference in clearance requirements? Seems I remember that forged ones required more clearance as they swell more coming up to temperature. Something about the material grain structure inherent to both processes. On the other hand I could be full of schiet. Happy Friday and ride safe, Steve
Since Jay says they're forged, we'll take his word, he's the man. But I'll add my $.02. You're right about microstructure. Maybe MTC uses a different alloy with a different thermal expansion coefficient, or a different heat treatment with the same results. They wanted tight clearances, and engineers can do this. I'm sure I could with a but of time, a materials lab like the one at my school, and the Aluminum volume of the Metals Handbook. And as for galling the piston, I would venture to say that smaller clearance would reduce it, not increase it. Greater moment arm for galling against the cylinder wall if you have more clearance.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
