KZ1000 oil pump drive gear
08 Aug 2008 11:02 - 08 Aug 2008 11:04 #230856 by steve3408
KZ1000 oil pump drive gear was created by steve3408
Has anyone thought of having a machine shop make a lower tooth count gear for the oil pumps on these old KZ's,same size,just fewer teeth so it would spin the pump a little faster,increasing flow and pressure,not a whole lot just a little.Instead of a 49 tooth gear,maybe something like a 42 tooth gear??...increasing flow about 20 % or so.Since after they get to operating temps,the pressure really drops to very little...2.8 lbs @3000 rpm.And yeah, i know it has roller bearings on the crank and all that, but its a plain ol' insert bearing in the top ends,the furthest point from the oil pump,cam insert bearings getting the least amount of lubrication.I know they typically hold up and last a long time, but if top end lubrication were improved,heck they might last a whole lot longer.Eveyone talks about "flow" instead of pressure being essential to these motors,well ok how can the "flow" be improved upon?...more output from the oil pump. Has anyone found a lower tooth oil pump drive gear that would interchange? or does someone make a gear like that for sale somewhere?
1980 KZ1000 A4(bought new),1979 KZ1000 MKII(bought new),1978 KZ1000 A (sold)1979 KZ1000 B LTD (sold)1976 KZ900 LTD (sold)1978 KZ750 twin (sold)
Last edit: 08 Aug 2008 11:04 by steve3408.
08 Aug 2008 11:27 #230864 by BSKZ650
Replied by BSKZ650 on topic KZ1000 oil pump drive gear
I havent looked at a break down, but the oil pump is going to have a pressure by pass someplace in the system, that is what you would need to modify the pressure, just spinning it faster is not going to do it alone.
and remember when you increase the pressure you are going to increase the heat in the oil, not such a good idea
77 ltd1000, current rider
76 kz900, just waiting
08 Aug 2008 12:50 - 08 Aug 2008 12:51 #230875 by bountyhunter
Replied by bountyhunter on topic KZ1000 oil pump drive gear
If the diameter uis the same and there are fewer teeth, the pitch of the gears will not match the drive gear on the crankshaft.
BTW: higher performance oil pumps are not higher pressure, they are increased volume.
Last edit: 08 Aug 2008 12:51 by bountyhunter.
08 Aug 2008 13:48 #230882 by wiredgeorge
Replied by wiredgeorge on topic KZ1000 oil pump drive gear
I am not sure it is a great idea to muck with the oil pump gear either. I would add some external oil lines to slosh the cam bearing area if I were concerned. The boy-racers do this and use braided steel lines to make it look hi-tech.
09 Aug 2008 14:02 #231030 by steve3408
Replied by steve3408 on topic KZ1000 oil pump drive gear
Increased volume would be okay too,dont see how that would be a negative.
The oil pump drive gears made for Suzuki's are made the same diameter as originals,and the teeth are matched to the right pitch,just fewer teeth on the gear.If it can be made for Suzuki's and work a little better,surely it would work ok on the KZ's too.They wouldnt sell them as an upgrade for the Suzuki racers if it didnt improve engine lubrication and function ok with it.
09 Aug 2008 14:20 - 09 Aug 2008 14:43 #231035 by steve3408
They might have an oil pressure by pass on the smaller bikes, but the 73-80 KZ1000's i dont think, have an oil pressure relief valve because they only operate in the 0 - 8 lbs range to begin with.A slight increase in oil pressure is not going to cause an increase in oil heat,Most KZ 1000's run in the 150-170 degree range when hottest,so how could oil presure (2.8 lbs. @ 3000 rpm)make any noticeable difference in the oil heat/temp.? If you think its running hot ,there are oil coolers available that would help that,and these are air cooled engines,remember,so there are a lot more factors that would manipulate the engine oil heat besides a very small increase in oil volume/pressure,such as outside temperature,how hard its being rode,the ambient wind temp around the engine while moving,proper tuning and maintenance,internal combustion efficiency,fuel octane rating,etc.....
Last edit: 09 Aug 2008 14:43 by steve3408.
09 Aug 2008 14:34 #231040 by steve3408
Now thats a pretty good idea,couldnt hurt having a little extra oil to the top end for the cam bearings.What it wouldnt use would just drain back down to the pan anyway.
The most critical time would probably be on start up,when its running for a little while before oil is getting pumped up to that area.I dont know how long that is, but probably what?...15-25 seconds maybe that its running with whatever oil was left behind on the bearings from the last run time.
So i guess spinning it over first, helps, before you "actually" try starting it,to get oil there maybe a little sooner.
10 Aug 2008 13:37 #231186 by bountyhunter
Hmmm... well it's been a while since I did any mechanical design, but I am not sure I understand how that can be possible. The teeth on the pump gear have to match the teeth on the drive gear (which stay constant). If you have fewer teeth on the same diameter wheel, it necessarily follows that the teeth must move farther apart from each other..... hence me not understanding how it would match the drive gear. If you change both gears, maybe that would work.
10 Aug 2008 17:42 #231230 by steve3408
An aftermarket oil pump gear with less teeth for spinning the pump a little faster is available for the Suzuki engine, i'm sure one could be made for the KZ as well,someone has figured out how to reduce tooth number,while keeping the diameter the same.I'm sure its just a matter of spacing,possibly taller teeth ?? maybe??
Someone with access to a computer assisted drafting program could probably design one pretty easily.
11 Aug 2008 06:32 #231332 by modprod
Replied by modprod on topic KZ1000 oil pump drive gear
Sorry but it just doesn't work that way. If you investigate I bet you'd find the Zuk mod requires 2 gears! What you are saying is physically impossibel. Sorry
11 Aug 2008 12:23 #231386 by steve3408
Sorry but i guess it does for the suzuki gear,Maybe you should investigate it,The "Suzuki mod" is a replacement gear (1)for the oil pump drive gear,
not two.I dont know how they did it,but it must be a different spacing,angles or tooth height.They obviously work since they are being sold to improve the oil pump output.If it can be done for the Suzuki, it couldnt be that much of a stretch to fabricate one for a Kawasaki.
And maybe its only a matter of one or two teeth on a gear to do that,although like you said a two gear mod would be more practical,something like maybe the gear drive instead of timing chains on cars.But no ones gonna make one for these old KZ's, they're dinosaurs now, so the new,cool ,hot products arent being designed for them anymore , but surely the technology is out there to make some improvements on the old ones too.We just have to be open minded test the limits.
I'm sure 20 something years ago, if you had said adding relays and mission specific wiring for the headlights and coils on the KZ would make it better,there would have been people saying it doesnt work that way,cant improve it,impossible,blah,blah,blah....
11 Aug 2008 15:06 #231410 by bountyhunter
modprod wrote:
Sorry but it just doesn't work that way. If you investigate I bet you'd find the Zuk mod requires 2 gears! What you are saying is physically impossible. Sorry
Yep.
BTW, just spinning a pump faster doesn't NECESSARILY buy you a whole lot as to improved performance in the pump. Pumps are a mechanical assembly designed to have certain flow characteristics. 30% more shaft RPM does not correspond to 30% more pressure or volume. It might do something better, but it's preferable to get an actual high performance/high volume pump if available. They used to make them for many car engines back in my hot rod days..... when dinosaurs roamed the earth.:laugh:
