Oil cooler yea or na
- Locozuna
As for do I want one..yes..do I really need one?...no at least not on my 650. It's stock and my climate is moderate but I feel it helps nonetheless. Personal opinion worth 2 cents. My 900 is pumped so yes I want and have one on her.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
- jrjstuff
Jeff
83 KZ750 ltd
- steell
I don't know how the aftermarket coolers are routed, but the easiest way by far on a 650/750 motor is to use a GPz750 oil pan. The oil passage from the pump on the 650/750 motors is routed down into the pan then back up to the motor, the GPz pans just separate the channel for one out and one in, and have ports on the pan for the cooler lines.
- wiredgeorge
- coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
- jrjstuff
Jeff
83 KZ750 ltd
- Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- Thank you received: 2098
... the accessory braided covers that make the ugly black hoses look a bit better.
If preferring the braided look, be sure to use a soft finish plastic/nylon braid and not stainless steel or other metallic braid. The lines do run along in direct contact with painted parts (frame and fuel tank) and wiring, and metallic braid will likely chafe and rub the paint off anywhere it touches, and could possibly rub through wiring insulation.
One thing about the ugly black hoses is that a charateristic of flat black color is that it sort of disappears into the background which helps it go unnoticed. And besides --- it matches the cooler. :laugh:
That's the reason for earlier mentioning possibility of mounting the cooler "upside-down" whereby the lines would more quickly disappear underneath the fuel tank.
Now, for those with a big pretty sparkling chrome cooler, nice gaudy matching bright braided lines would seem a must. :laugh:
Good luck with whatever is decided!
- steell
The GPz750 pan will fit all the 650's and 750's, I sold three or four to members here for both.
Only have one pan and oil cooler set up left, and it's going on my 80 KZ750E
Kawasaki didn't think a bypass was needed, since they didn't put one on the gPz750's.
I don't think the GPz750 was designed to be ridden when it was really cold though
- kxhonda
1977 Kz650B1 #576th made.
Warsaw, In
- RetroRiceRocketRider
- Thank you received: 29
I'm looking for a GPZ oil pan right now, but I'm not having much luck.
The oil pan on a ZR750 (Zephyr) also has an integrated oil cooler with the lines run to the front of the oil pan, and just happens to use the exact same pan gasket that's used on the KZ650's/KZ750-4's.
So basically, the 750 Zephyr oil pan should also be a direct bolt-on to any KZ650/KZ750-4.
The 750 Zephyr was made for fewer years than the GPz750's, so finding a used oil pan from one might prove even more difficult than one from a GPz. But the Zephyr being a newer model (last year was '92 or '93 IIRC?), chances are that a NOS oil pan can still be bought through Maw Kaw.
I'm running GPz750 oil pans/coolers on my '78 KZ650 and my '84 ZN700 LTD (basically a de-stroked KZ750-4) here in So Calif, and it DOES make a big diff during the summer, especially in rush-hour traffic!
Here's a few pics (click to enlarge) of the GPz oil cooler and pan on my ZN700.
If you want to see how I mounted the pan and cooler on my 650, just let me know.
- KZ 82 750 LTD Guy
