Oil cooler yea or na
- jrjstuff
19 Mar 2008 08:34
I may seem a bit on the dumb side for asking this but I have always gotten great feedback here! On my 82 kz 750H I have one of those Lockhart oil coolers. The bike is still in a project phase, and I am wondering if it is necessary? Is it really benificial? And if so, how can I make it look better. This one is older and the lines to and from look fairly wore out, not to mention they appear to leak on the bottom end. I know there are a lot of guru's out there so please give me some opinions! Thanks!!
Jeff
83 KZ750 ltd
83 KZ750 ltd
- StreetfighterKz
Re: Oil cooler yea or na
19 Mar 2008 08:38 - 19 Mar 2008 08:39
Are you running a bigger piston kit? Are you running a higher than stock CR? Do you do a lot of stop and go driving in a hot climate? If you answer "No" to one or all of those questions then you probably won't need a cooler.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 19 Mar 2008 08:39 by StreetfighterKz.
- jrjstuff
19 Mar 2008 08:49
That would be all no's except for climate. I am in central CA and the summers are pretty hot here but I always keep good oil in it. So my next question is, how do I remove it? Its a stock bike aside from a 4 into 1.... for now!!!
Jeff
83 KZ750 ltd
83 KZ750 ltd
19 Mar 2008 09:10
Have wondered about possibility of mounting oil cooler "upside-down" to show less oil line hose before it disappears underneath the fuel tank.
Oil cooler lines from engine fittings loop up behind carbs and run along frame rails underneath fuel tank to oil cooler.
- bountyhunter
19 Mar 2008 09:13
jrjstuff wrote:
I wish somebody had made a cooler to fit my 750 twin, I definitely wanted one (still do, I don't believe they exist). I live in north Kali and it doies get hot here. I had an oil pressure gauge on mine for a while, and the hot idle oil pressure on mine was dropping to about 15 psi. I sure wish I had an oil cooler on mine, don't know why you'd want to junk it.That would be all no's except for climate. I am in central CA and the summers are pretty hot here but I always keep good oil in it.
- bountyhunter
19 Mar 2008 09:16
jrjstuff wrote:
I believe you'll need the original fittings for the oil pressure sender and also the drain plug is usually modified for the oil return path on an aftermarket cooler.So my next question is, how do I remove it? Its a stock bike aside from a 4 into 1.... for now!!!
