- Thank you received: 14
Low compression, weighing options.
- BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
- steell
I think so.
Five 750 four cylinder blocks, four were so oval they needed bored oversize, other one was oval also, but not so bad it couldn't be honed to size and still be within service limits.
I haven't checked any 1000 blocks, but it seems to me that the same thing would probably happen.
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
- Thank you received: 3
is it low compression? induce some pinging to seat the valves and rings........no.
just go flog the thing like theres no tommorow, if that doesnt seat the rings nothing will.
i thought i heard someone say 1075 kit?
After I put the bike back together, I took it out to a long, flat, country road and did a couple dozen cycles of WOT in 2nd gear up to 8500 RPMs then coast back to 2K and repeat.
Oh, and I have thought about the 1075 kit. Maybe someday.
West Linn, OR
- Skyman
one thing I may have missed, did you hone the cyls, ? if so how did you do it,
Yes, I did. When I took it to the machine shop to do the valves, I had them hone the cyls too.
West Linn, OR
- nads.com
- Thank you received: 20
- jjdwoodman
- Live free, or die.
How much does a set of rings cost? (the cheap ones, not the chromemoly)
How much does a set of geskets plus labor to install rings if you're wrong cost?
I would think you would be better odds to get the rings.
One major factor in my reasoning is this... You said you do think you oiled the pistons when you assembled, so you have at least decent odds that your current problem may be glazed cylinders, and rings. so those rings may not seat in the new cylinders either.
Another is you suspect oval cylinders may be your problem, so that could give you uneven wear on your rings. (sure it's not much, but your putting a good bit of money on the other side of the combustion chamber, why not make the rings right too.)
As a side note, it is very common for cylinders to be
SLIGHTLY oval when they are COLD! That's one of the reasons your engine has out of round specs.
Theoretically as the engine warms up, the cylinders become more round and the compression goes up. Which leads to a new question... did you check compression both cold and at normal running temp and are they the same?
I would think you might still have a chance at getting your rings to seat, if that is indeed your problem.
Some ideas I've seen kicked around to get a booger set to seat,
1. pull the plugs, wash down the cylinders with B12, replace the oil with mineral oil, or alternatively, crank the cylinders over for 15-20 seconds dry. Drive as usual.
2 run transmission fluid in a tank of gas. ( will barely run and will smoke like a freight train) This has also been used as a cleaning method for cabon buildup on valves.
I've tried no 1 with limited success. never tried no 2 for that.
good luck and best wishes.
77 650b
81 550 Mostly there
83 ZN1300 Voyager
- wrenchmonkey
- Thank you received: 75
With 43,000 on the motor the bores are too big now and no set of rins is going to make any compression, Your rings did seat. You were lucky to get 100lbs. Those clingers are Toast. Out of round, tapered, when u measured with the gauge it should have read HUGE!.
(SNIP)
How bout another question on compression? :woohoo: :woohoo:
Wow! If understand this correctly. You're saying an engine is toast at 40k miles? Holy shit Batman! :pinch:
This is interesting because the person that started this thread mentioned he had a machine shop hone the bores...
I wonder why they didn't mentioned "oh by the way... yer gunna need a new set of pistons and rings cause we just chewed x thousands off the walls to get'em back to cylindrical from their ovaled-out shape!"?
Is this something common to that model or do all KZ's suffer from this sort of short engine life expectancy?
- donthekawguy
- Thank you received: 8
(SNIP)
Most KZ's never see those kind of miles (except Ron's) because they are run hard. look on ebay and you will see the average mileage of a 25-30 year bike is around 25K. But that is a hard 25k, at least on my bike it is.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- jjdwoodman
77 650b
81 550 Mostly there
83 ZN1300 Voyager
- nads.com
- themachine
- Thank you received: 4
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
- Thank you received: 2098
Perhaps the machine shop was engaged to do a valve job and to de-glaze the cylinder walls with a honing brush, but not requested to measure the bores or test fitment of pistons or rings.
Is re-sleeving not a feasible option?
