New owner need help
- Csr750_dave
Re: New owner need help
15 Aug 2015 08:07 - 15 Aug 2015 08:18
Thanks for all the replies my bike is a 1980 csr 750 twin. The cluster i found is for a 1980 kz 750 ltd it don't say if it's for the twin or 4 tho. If the brackets the same and dash is the same i,can always change the gauges out. I didn't think there would be much of a difference from a 1980 csr 750 and a 1980 kz 750
Last edit: 15 Aug 2015 08:18 by Csr750_dave.
15 Aug 2015 11:07 - 15 Aug 2015 11:23Rendering Error in layout Message/Item: Kunena\Forum\Libraries\BBCode\KunenaBBCodeLibrary::renderEbayLayout(): Argument #1 ($ItemID) must be of type int, string given, called in /home/kzride5/public_html/libraries/kunena/src/BBCode/KunenaBBCode.php on line 314. Please enable debug mode for more information.
- Csr750_dave
15 Aug 2015 11:14 - 15 Aug 2015 11:16
Well what I did for 20 bucks I ordered them because I need the indicators and bracket for it anyway so to me the bracket and dash indicator are worth 20 bucks so it the gauges work great if not not a big deal I'll order the correct ones. And if these don't work I'll re list them to get my money back.
Last edit: 15 Aug 2015 11:16 by Csr750_dave.
15 Aug 2015 11:26
I just put up the page link in my last post. Selling on eBay is a PITA. If you're new, they will hold your money for 10 days or until the buyer signs of on it.
- Csr750_dave
15 Aug 2015 11:40
I have sold on ebay before but for 20 bucks I'm not gonna complain really if i can't use the gauges that's fine as long as the bracket and stuff works I'll be happy with the purchase cuz right now there is no cluster on the bike I also have to order a tach cable it was cut off at the motor hopefully it didn't strip anything. I kicked the bike and it ran for a little I just gotta clean the carbs he also said that the starter needs to be rebuilt so I'll have to rebuild it
15 Aug 2015 12:09
It is pretty rare for a starter to go out on a KZ. Much more common is a worn starter clutch. Do you know what the symptoms are?
15 Aug 2015 12:43 - 15 Aug 2015 12:48The 750-CSR Twin is a 1982 model. In 1980 there was 750-G1 Ltd II Twin. The bike in the photo appears to be an 82.Csr750_dave wrote: Thanks for all the replies my bike is a 1980 csr 750 twin. ...
Kawasaki.com. partzilla. CycleChaos.com.
Last edit: 15 Aug 2015 12:48 by martin_csr.
- Csr750_dave
15 Aug 2015 12:56
I'm loving this site so much great information thanks guys I was going off what the guy told me so it may be a kz I'll have to look at the title as far as the starter he said it just spins that it don't turn the motor over
15 Aug 2015 13:03
Starter clutch.
- Csr750_dave
15 Aug 2015 19:01 - 16 Aug 2015 09:28
So I got it running but noticed the carbs seem wierd and I noticed the exhaust says kz750m and the bike is a 1982 so now I gotta start fixing things but my issue is the carbs it has mikuni carbs on it now and they look much different from the other sets I have that came with. So it's a bit annoying fixing all the junk the previous owner messed up
Last edit: 16 Aug 2015 09:28 by Csr750_dave.
- Csr750_dave
16 Aug 2015 10:19 - 16 Aug 2015 10:20
Not sure what carbs are correct the ones on the left are the ones that are on the bike now.
These are what's on the bike now
I have 2 sets of these
Last edit: 16 Aug 2015 10:20 by Csr750_dave.
16 Aug 2015 11:04
Looks like the ones with the chrome tops are the ones for your bike. Do the thumb test on the carbs to check the diaphragms.
