- Thank you received: 1656
New owner need help
17 Aug 2015 09:34 - 17 Aug 2015 09:37 #686080
by martin_csr
Replied by martin_csr on topic New owner need help
The Kaw site should recognize the vin. The c.c. site left out one "1" in the frame number (vin).martin_csr wrote:
The 750-CSR Twin is a 1982 model. In 1980 there was 750-G1 Ltd II Twin. The bike in the photo appears to be an 82.By Csr750_dave: Thanks for all the replies my bike is a 1980 csr 750 twin. ...
Kawasaki.com. partzilla. CycleChaos.com.
Last edit: 17 Aug 2015 09:37 by martin_csr.
- Csr750_dave
17 Aug 2015 10:50 #686088
by Csr750_dave
Replied by Csr750_dave on topic New owner need help
- Csr750_dave
19 Aug 2015 18:57 #686433
by Csr750_dave
So sadly I made the decision to let the bike go i hate to let it go but after working on it a bit it seems like this bike was built from junkyard parts or numerous bikes so I may salvage what I can off it and sell it for parts. One think I like are the spoked wheels and Im gonna try to see if I can use them on my other bobber.this is my first bike I built a 1980 honda cm 400t if anyone knows the diameter of the front and rear axles that would be great since they are both cable driven speedos I can make ot work somehow.
20 Aug 2015 05:30 - 20 Aug 2015 05:30 #686461
by martin_csr
If needed, you could swap out the bearings to mate the axle to the wheel --- bearing OD to fit the wheel & ID for the axle.
From the wheel bearing numbers at Kawasaki.com & using a bearing chart from Dans MC site,
the Fr ID = 15mm & the Rr = 17mm. ..... Partzilla should have the bearing numbers for both models.
Last edit: 20 Aug 2015 05:30 by martin_csr.
- Csr750_dave
24 Aug 2015 11:12 #686999
by Csr750_dave
So sadly this is where my adventure ends I sold the bike but it went to a much better owner he works at a motorcycle shop and will have her fixed up and back on the road. Maybe if another twin comes around I'll pick it up til then I'll ride my faithful little honda til then
- LineArtist
- Thank you received: 35
24 Aug 2015 11:15 #687000
by LineArtist
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
Replied by LineArtist on topic New owner need help
peace
'79 KZ650B3 (stock)
'06 HD 883R
