MOVED: Hit and run accident in Chicago
- krayneeum
Re: MOVED: Hit and run accident in Chicago
25 Jun 2015 15:33loudhvx wrote: He lives a few blocks away and the cops can't even go knock on the guy's door? WTF.
I'm in Humboldt (next neighborhood over for those not in Chicago), and have been in the Logan/Bucktown/Humboldt area for 25 years... but it's time to get out. Too insane. Austin district is now the murder capital of Chicago, or at least it was a few months ago.
If you get another bike and need help getting it up and running, let me know.
Thanks man! Scoping out craigslist for new bikes already. Once I get my check I'm going shopping haha. I'm in Noble Square, pleasure to meet another KZ owner in Chicago!
- krayneeum
25 Jun 2015 15:35jeff80kz1000e2 wrote:swest wrote: 72 hours or forget it. They have to prove he was driving. $1500 damage? Not worth their time.
You called it Steve. I just figured since it could have easily been worse for our fellow rider I would see about helping him out.
The cop friend said there are separate task forces who deal with these, lol. Had it been in his district he may have been able to get someone to put this at the top of the pile, but like you said, prove who was driving. Seems like such bs, but what can you do.......
One thing the cop said was look around for eyes in the sky ( video camera's ) nearby that could have caight the A Hole driving said vehicle and if so, ask whoever you can to see footage of those cameras. Jeff
Personally its a principle thing here regardless of property damage and its worth looking for a camera or two to try to bring some justice to the schmuck driver......
Ah, well thanks for trying man! I'll have to double check but I'm fairly certain there are no cameras at the main intersection I saw him go through. Worth a look though for sure.
Much appreciated!
- krayneeum
25 Jun 2015 16:04
Pics!
imgur.com/a/CyFH1#0
Cosmetically, it's honestly not too bad. Mostly minor stuff. But the engine is pretty well seized. Tried to kick it and it was very stiff, but moved a little. The full force of the impact was right on the edge of the engine. Probably knocked the cylinder/piston out of alignment or something?? Would probably need a full rebuild I imagine.
The question is.. is it worth $340 to keep?
Still several sellable parts I could maybe turn a profit -- or -- maybe a potential project? My friend has a KZ750 shaft engine.. :whistle:
- floivanus
25 Jun 2015 16:07
Seems like everytime I go to chicago traffic seems to be worse than the last time I was out there.
Glad you're alright, all things considered that pic doesn't make the bike look too bad; might be somewhat salvagable.
Past; 78 kz1000, 83 kz550
Andrew
Andrew
25 Jun 2015 16:22
Bossie was DOA. Broken clutch cover, ignition housing frame tweaked, swing arm folded, busted speedo, etc. When I got to the salvage yard, someone had started to take the carbs.
Bastards. I was in a leg and arm cast, they didn't expect me, paid $300, took it home. Two years later, we were back on the road. From then on, the bike is a legend. :woohoo:
I'd fix it.
I'd fix it.
- zukdave
25 Jun 2015 18:14
Hell yes pay the money and keep it
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- roy-b-boy-b
26 Jun 2015 08:03
Glad you are Alright.
When I hit the truck that pulled out in front of me my engine was damaged also. I pulled the head and jugs off for replacement. The jugs were bored to 1075 so I pulled the cylinder out of the jugs and installed them in another set. I checked the rods out and have run this engine a lot since then.
Just check everything out.
- Tyler
26 Jun 2015 11:28
You sure the stator cover didn't get hit? that would bind up the motor. The head took the brunt of it, so the cams may be what's binding. I have a couple heads for 650's. If you repair this engine and need one let me know.
"74 Yamaha DT 400 Enduro
- DoctoRot
26 Jun 2015 11:30
Glad you are OK. That is infuriating about the police though. We have a similar problem with theft in Seattle right now. The cops will do nothing unless the person is in the act. Because of the lack of punishment there has been a brash of break-ins. What the hell do we pay their salary for? Oh yeah, to cite people for traffic violations that bring in money to the city... Sigh. If you have the time and means i would buy the bike back. Looks like the chrome is pretty good, and perhaps many parts are salvageable. If you end up using that frame, check it for straightness.
26 Jun 2015 13:02
It all goes down to the lack of community involvement and only 17% of registered voters that actually vote. Of course they will get what they want at the expense of the others. They want their entitlements but they don't want to pay for say prisons. There's no where to put the criminals so they're on the streets and on and on, atnauseum. :sick: Cops are the tools of the system that employs them. I've been involved in LE for the last 19 years. Felons get caught and are out on the streets before the ink dries on the report.
- loudhvx
26 Jun 2015 17:14 - 26 Jun 2015 17:26
This might be exactly what you need.
chicago.craigslist.org/chc/mpo/5085338112.html
It's listed as a 79, but it's clearly a 77. The difference is in the alternator/regulator/rectifier. You can see the three screw holes on the alternator cover in the shape of a triangle. Your 77 should have this too, if it's truly a 77.
May need the starter clutch replaced, but since the engine is already out, the job won't be too bad. I would try to talk him down based on the year and if you don't need the carbs, especially since you can't start the motor, and you can't even test the compression.
10 years ago, I wouldn't pay more than about $50 without a guarantee that it is in good condition. Without it, you are taking a lot of risk that it may be a boat anchor.
Kedzie and 63rd (Marquette park?) is kind of a war zone, so I wouldn't be happy about going out there.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 26 Jun 2015 17:26 by loudhvx.
26 Jun 2015 19:18
Stolen? I'd be careful. :whistle:
