Z2 750 crank (Bossie the Kaw)
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
Re: Z2 750 crank (Bossie the Kaw)
01 Aug 2020 15:33
#832047
They seem to work. B)
  • hardrockminer
  • hardrockminer's Avatar
01 Aug 2020 15:38
#832049
You can get the length of any bolt from the Partzilla parts diagrams. The long ones are Part # 112G06125. The last 5 numbers indicate that it's a M6 bolt, 125 mm long.
  • Mikaw
  • Mikaw's Avatar
01 Aug 2020 19:20
#832059
SWest. Glad to see so far they are working out. If the bolt is bottoming out, could you just cut 1/4” of thread off?
  • SWest
  • 10 22 2014
01 Aug 2020 20:52
#832072
That's what they say you might have to do.
  • SWest
  • 10 22 2014
02 Aug 2020 06:54
#832095
Now to RIDE. :woohoo:
  • SWest
  • 10 22 2014
04 Aug 2020 18:45
#832244
They were glazed.
  • SWest
  • 10 22 2014
04 Aug 2020 21:13
#832257
I should have cleaned all the plates.
  • Greybeard
  • Greybeard's Avatar
05 Aug 2020 06:29
#832272
Are those springs still in spec?
1982 KZ1100 D-1
  • SWest
  • 10 22 2014
05 Aug 2020 06:45
#832273
Well over spec. It must have been the pre mix I'd been using to flush out the engine.
The following user(s) said Thank You: Greybeard
  • SWest
  • 10 22 2014
06 Aug 2020 15:17
#832345
Should have done this the first time.
  • SWest
  • 10 22 2014
06 Aug 2020 19:44
#832352
Looks like it will work.
  • SWest
  • 10 22 2014
11 Aug 2020 07:44
#832648
More to do but at least I can ride.
