Ebay Yoshimura exhaust- was it worth the price?
  • porchev914
  • porchev914's Avatar Topic Author
Re: Ebay Yoshimura exhaust- was it worth the price?
06 May 2010 18:57
#366053
Then I noticed a small dent in the #4 primary tube. Seller must have overlooked disclosing that one.....hmmmmmmmm :huh:
I don't believe it will affect performance, just an asthetic drawback
FRANKEN Z!
  • porchev914
06 May 2010 19:00
#366056
Then there were 2 small pinholes in the bottom 2 primaries near the collector. Again, the seller must have accidentally overlooked disclosing that one too.....Luckily, that was the last of the "problems" not disclosed int he auction
FRANKEN Z!
  • porchev914
06 May 2010 19:15
#366064
I was AMAZED at the size of the collector/muffler tubing size. I had read it was 3",but I wasn't prepared for how BIG it would look in person :ohmy: :blink: :P
FRANKEN Z!
  • porchev914
06 May 2010 19:21
#366066
Oh yes, one more item the seller omitted- the Yoshimura emblem on the tailpipe had one pin sheared off :angry:
FRANKEN Z!
  • porchev914
06 May 2010 19:33
#366073
At least the core is in good shape. The packing was non-existant, but it was straight and complete
FRANKEN Z!
  • dutchz
  • dutchz's Avatar
06 May 2010 19:51 - 06 May 2010 19:53
#366079
Well, a lot of it is fixable and won't be very visible when mounted. The dent in the #4 is a bummer, may be difficult to pull out. You are right about the 30yr old parts, but calling that pipe in "good shape" like the seller did, is pushing it if you ask me. Been there, done that...
1974 Kawasaki Z1
Stock front hub and rear axle.
Last edit: 06 May 2010 19:53 by dutchz.
  • porchev914
06 May 2010 21:20
#366092
With regards to the dent, I believe I can weld a stud on there and use a slide hammer to pull it out......mostly :unsure:
FRANKEN Z!
  • porchev914
06 May 2010 21:36
#366099
I was also suprised how rough the inside of the collector looked.....not that I could have done a better job :laugh:
FRANKEN Z!
  • kzmk2
  • kzmk2's Avatar
06 May 2010 21:37
#366100
It would be interesting to try a perf tube baffle in your yoshi pipe. I did some dyno testing comparing perf tube vs louvered silencers and the found for the same size diameter a perf tube flows much better than a louvered tube. I have a Kerker KR on my MKII and built my own aluminum tail pipe. Originally I used a Yosh competion baffle, but then switched to perf tube. Seemed to have alot more power with the perf tube.
  • porchev914
06 May 2010 22:01
#366104
What does a Yosh Competition baffle look like kzmk2?
FRANKEN Z!
  • kzmk2
  • kzmk2's Avatar
06 May 2010 22:10
#366106
Looks the same as the street baffle, just larger diameter. I don't remember the diameter I would have to measure my end cap ID to know for sure. I removed the Yoshi steel end cap so I could slip the baffle into an aluminum can with aluminum end cap.
  • porchev914
06 May 2010 22:17
#366108
What size perf tube did you go with, and how much louder did it get?
FRANKEN Z!
