How do you do a burnout / wheelie?
  • Jimbo302
  • Jimbo302's Avatar
Re: How do you do a burnout / wheelie?
19 Nov 2009 16:37
#334685
A standing still, smokey burnout requires use of the front brake and a prodigious amount of throttle before and after a quick clutch engagement. First gear works fine and probably best without a waterbox.
Practice your wheelie from a rolling start first. Every bike is different and requires a certain posture and throttle modulation. Get rolling in first and let out the clutch while throttling it up, repeat until you get the feel for it.
Remember all these things eventually will damage your bike and you, so use in moderation.
Here is a good wheelie I had:
  • likes2gofast2009
  • likes2gofast2009's Avatar
19 Nov 2009 17:12
#334698
I agree with the rolling burnout first, make sure you're heading straight and are well balanced otherwise the rear of the bike will swing to one side.
My first wheelie I was rolling in 1st gear around 3500-4000rpm and just opened the throttle wide open while shifting my weight backward, just make sure you can control the throttle and have your foot ready on the rear brake incase you go up an too much of an angle, this will help you from flipping the bike or dragging the rear fender.
Be careful and if you hadn't been riding long I don't suggest trying this, or go out in the dirt and practice on a dirt bike, its way easier (and less painful haha) to learn that way.
1980 KZ1000 LTD "Brandi"
4-1 Kerker
Dyna Coils
More to come this winter!
  • racer54
  • racer54's Avatar
19 Nov 2009 17:41
#334705
Out in front of the house when I'm just playing around, I'll use first gear but at the track, I will use 3rd gear for the burn-out. Gets the tire spinning faster and I don't have to use such high rpm to get desired results. If you want to use 2nd gear, use water to help break tire loose so it doesn't shock the gear too much. This is one of those deals where very little water goes a long, long ways. Just enough to get tire spinning as it WILL make the tire slippery and harder to control, needless to say. 2nd or 3rd gear will be easier to control though. Also, be sure to let off gas if you think tire is starting to hook otherwise you may get to practice those wheelies before you are ready!:blush:
  • arai59
  • arai59's Avatar
19 Nov 2009 17:45
#334706
PLUMMEN wrote:
wheelies are easy crack the throttle on a bigbore missile and hang on.i remember racing my z1 against an h2 750 when i was a kid,looked over he was dead even at around 90mph but his front wheel was 2' of the ground! :blink: :woohoo:
:laugh: do the grand fables ever end ? :laugh: you and your buddy rock !
  • arai59
  • arai59's Avatar
19 Nov 2009 17:50
#334708
I want me one of those turbo Plummen motors ! They rock !
  • Kraz1
  • Kraz1's Avatar
19 Nov 2009 18:36 - 19 Nov 2009 18:40
#334727
Can\'t post the link. Sorry.
Last edit: 19 Nov 2009 18:40 by Kraz1.
  • PLUMMEN
  • PLUMMEN's Avatar
19 Nov 2009 18:41
#334730
youwork out your issues with the kz440 first and we'll work you up to a 650,remember baby steps! :laugh:
  • PLUMMEN
  • PLUMMEN's Avatar
19 Nov 2009 18:44
#334733
you couldnt afford the boost gauge B)
  • PLUMMEN
  • PLUMMEN's Avatar
19 Nov 2009 19:36
#334751
:woohoo:
  • arai59
  • arai59's Avatar
19 Nov 2009 19:42
#334756
Only if I could...........
  • PLUMMEN
  • PLUMMEN's Avatar
19 Nov 2009 19:49
#334762
arai59 wrote:
bet I could...........toilet boy..:laugh:
well roll on up here then,ill make ya hell of a deal! :woohoo:
  • arai59
  • arai59's Avatar
19 Nov 2009 19:51
#334764
its a deal Jimmy.....it's a deal.
