1978 KZ1000 Project
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 1978 KZ1000 Project
09 Dec 2024 17:40 - 09 Dec 2024 17:43
#906776
The main jet size number location is on top for the main jets.
The pilot jet size mumber is imprint on the lateral circumference and not on top!!!
Last edit: 09 Dec 2024 17:43 by Scirocco.
The following user(s) said Thank You: rstnick
  • rstnick
  • rstnick's Avatar Topic Author
  • Premium Member
  • Premium Member
15 Dec 2024 16:57
#906893
The handlebar switches need to be notched to allow the wiring to escape when fitting to other handlebars.
The Kill switch was broken.
I was able to repair it using a spare.
Wrapped the wires when completed.
[IMG
[IMG
[IMG
[IMG
[IMG
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • KZQ
  • KZQ's Avatar
  • Away
  • Administrator
  • Administrator
15 Dec 2024 20:34
#906898
Hello rstnick,
There was something wrong with your last post which forced me to delete it. Would you please recreate it?
Thank you
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • rstnick
  • Premium Member
  • Premium Member
16 Dec 2024 15:22
#906911
Sorry about that Bill.
Probably me trying to attach a video.
Worked on the Gauge cluster's wiring.
The blue wire/circuit was broken, and once I finished repairing that, the Brown wire/cicuit did the same thing.
[IMG
[IMG
Wires soldered:
[IMG
Shrink wrapped:
[IMG
Then all taped up and rear gauge cover put on:
[IMG
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • rstnick
  • Premium Member
  • Premium Member
16 Dec 2024 15:28
#906912
Can someone post a picture of under the seat?
On a 1978 KZ1000 or simialr.
I want to see how the air box sits etc.
I have a Service Manual, but did not find any under seat pictures.
I imagine the air filter can be changed easily?
Thanks.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
16 Dec 2024 15:34 - 16 Dec 2024 15:36
#906913
Rob I don't want to be a smart ass but that joint on the blue is going to give you problems later. that looks like you melted the solder with the iron rather than heating the wire and melting the solder on  by laying it on the cable. If there is any "blackening" on the cable it will oxidise and not solder correctly. These sleeves from Amazon etc are a better option and cheap enough
Last edit: 16 Dec 2024 15:36 by Wookie58.
  • rstnick
  • Premium Member
  • Premium Member
16 Dec 2024 16:50
#906916
I did do a little of both; I first heated the wires only, then applied solder to the opposite side, and I could see the solder drawn across.
I then added more Solder, so that kind of got painted on.
I think it will be fine.
Otherwise it will need rodoing one day.
Thanks for the heads up and tips.
It is a rosin core solder, and seems to stick to the copper wiring well.
Other solder I have, and tried, doesn't seem to stick.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • rstnick
  • Premium Member
  • Premium Member
21 Dec 2024 13:48
#907055
I hate putting together something someone else took apart.
The KZ1000 is similar, yet different than the KZ650 I know so well.
For instance, the air box fitting.
There are two posts on the bottom of the 1000's air box.
I assumed they lined up with the support that's already there, between the frame.
This support doesn't come close to the air box. Must be for the battery box?
The air box sits forward and about an inch below the support.
I tried looking at parts diagrams, but not seeing a support bracket for the bottom of the air box.
Nothing on the sides of the air box, like the 650's.
If someone can help me with how the bottom mounts up would be great.
If anyone can take some pictures (or I can try searching through some threads) of under the seat and side covers.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • rstnick
  • Premium Member
  • Premium Member
21 Dec 2024 14:03
#907056
Is either part #18 or #20 the air box support?
[IMG
Again some pictures would help routing some of the wires, as it was worked on before me.
[IMG
[IMG
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • rstnick
  • Premium Member
  • Premium Member
22 Dec 2024 16:07 - 22 Dec 2024 16:09
#907077
My parts order came in from Z1E.
[img
Changed the one broken Choke plunger spool:
[img
[img
[img
Checked what Pilot jets were in the carbs: 15
Which is stock for the year.
I was suspecting other jets in the carbs because there were Pod air filters on her.
Gave them a bath and cleaned them out, as I couldn't see through them to start.
[img
[img
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 22 Dec 2024 16:09 by rstnick.
  • rstnick
  • Premium Member
  • Premium Member
22 Dec 2024 16:15
#907078
Had another go at removing the Points plate screws.
My Impact driver bit was worn out, but having sprayed the screws with some penetrating oil the day before, I managed with a bigger hammer and a screw driver to loosen the screws.
The larger screws holding the points housing to the engine I was able to use the Impact Driver with a larger bit.
Housing off, and gasket scraped.
Ready for reassembly.
[IMG
[IMG
[IMG
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
The following user(s) said Thank You: SWest, Wookie58
  • rstnick
  • Premium Member
  • Premium Member
26 Dec 2024 14:51 - 27 Dec 2024 01:37
#907179
Have figured out a little more of the puzzle.
Seems part #15 supports the airbox:
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 27 Dec 2024 01:37 by Wookie58.
