Racecrafters project pics.
- DOHC
- Those Doe-Hawks really go!
Re: Racecrafters project pics.
07 Sep 2024 07:28 - 07 Sep 2024 07:29I found these pages, which look to be the systems you mention:
www.electrexworld.co.uk/acatalog/Kawasak...-3110--RPK_3110.html
www.electrexworld.co.uk/acatalog/RPKS-31...ternator_System.html
The manufacturer only mentions compatibility with 1981 and later "J" model derived engines.
However, you also mention the "Mk2" crankshaft. Can you confirm that this kit is compatible with the 79-80 KZ1000 Mk2 crankshaft and engine cases?
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
Last edit: 07 Sep 2024 07:29 by DOHC.
- zed1015
07 Sep 2024 07:59 - 07 Sep 2024 10:31Yes! it fits the MK2 crank.I found these pages, which look to be the systems you mention:
I'm going to use another on my turbo build below which i have a MK2 crank for and all the big aircooled fours use the same alternator case bolt pattern so the cover will physically fit all Z1 through to GPZ1100.
If you are considering buying the enclosed 3112 version there is a design fault and the outer cover doesn't block off the main oil gallery like original does so you will have to make a bung to stop the oil short circuiting back to the sump rather than feeding the head and it is also worth checking the rotor alignment to ensure the stator winding sits central in its magnetic field to ensure maximum output.
Here's a link to page 15 of my build thread over on the Z1 forum which shows the oil gallery bung etc .
Double the troubleZZ. AMA style Racecrafters Z1000 (completed) and Moriwaki Z1R Turbo. - Page 15 - Z1OwnersClub GB
Last edit: 07 Sep 2024 10:31 by zed1015.
The following user(s) said Thank You: DOHC, Scirocco
- Ilfrid
27 Sep 2024 10:47
Hey Zed beautiful bike.
Could you tell me what Swingarm you used ? and what rear tire size are you running?
Loved all the fabrication work!!!
Mexican guy starting a Resto-mod project of a Z1 900 or Z900??? not sure
Current Bikes
1976 Z900 I think
1992 Harley FXR
2007 Harley Electra
Current Bikes
1976 Z900 I think
1992 Harley FXR
2007 Harley Electra
- zed1015
27 Sep 2024 11:18The swingarm on the Racecrafters is a Yamaha XJR1300SP with 11mm machined off each end of the pivot and the rear wheel and tyre is 5.5 inch rim with 180 tyre which is the maximum you can run true central ( with 5/8ths offest front sprocket ) without having to scallop the frame for the chain run.Hey Zed beautiful bike.
- Ilfrid
27 Sep 2024 13:21
I love the look of the XJR1300 swingarm in this bikes, ever since I saw that Sanctuary used it on a Z2.
Now I'm convinced to get one for my bike, bad point is here in Mexico we didn't get the XJR models.
I guess I will buy it on Ebay from a UK supplier.
I hope you could post some pictures on how you adapt it to your frame, that would be very helpful.
Anyway your bike is awesome and I really hope you post the advance in the turbo bike.
Current Bikes
1976 Z900 I think
1992 Harley FXR
2007 Harley Electra
Current Bikes
1976 Z900 I think
1992 Harley FXR
2007 Harley Electra
27 Sep 2024 15:05 - 27 Sep 2024 15:12
If you want I can help you with the buying and shipping from Germany to Mexico.
www.kleinanzeigen.de/s-anzeige/yamaha-xj.../2844028639-306-1961
Go to ---> www.ebay.de and search ---> 384780672181
Last edit: 27 Sep 2024 15:12 by Scirocco.
- zed1015
28 Sep 2024 09:18 - 28 Sep 2024 09:19Every one of these XJR arms i've fitted needs exactly 11mm taken from each side of the pivot and the same goes for bearing tube along with sinking in the needle roller bearings .
I also line bored the frames to take a 20mm spindles rather than sleeving the bearing tube.
I have build thread over on the UK Z1 site which you would be better off reading rather than me trying to paste all the relevent info here and then missing something out..
Double the troubleZZ. AMA style Racecrafters Z1000 (completed) and Moriwaki Z1R Turbo. - Z1OwnersClub GB
Last edit: 28 Sep 2024 09:19 by zed1015.
The following user(s) said Thank You: sf4t7, Scirocco
- Ilfrid
30 Sep 2024 09:26Scirocco post=904667 userid=48181
Hi Scirocco, thank you for the offer.If you want I can help you with the buying and shipping from Germany to Mexico.
Le me consider it since my image is to start buying parts at the beg - mid of next year.
I will let you know.
Current Bikes
1976 Z900 I think
1992 Harley FXR
2007 Harley Electra
Current Bikes
1976 Z900 I think
1992 Harley FXR
2007 Harley Electra
- Ilfrid
30 Sep 2024 09:33zed1015 post=904698 userid=14135
Wow that's perfect.Every one of these XJR arms i've fitted needs exactly 11mm taken from each side of the pivot and the same goes for bearing tube along with sinking in the needle roller bearings .
I already started reading the thread and it's really detailed.
Thank you
Current Bikes
1976 Z900 I think
1992 Harley FXR
2007 Harley Electra
Current Bikes
1976 Z900 I think
1992 Harley FXR
2007 Harley Electra
