And finally, Wookie's 82 begins !
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
Re: And finally, Wookie's 82 begins !
22 Jun 2026 18:22 - 22 Jun 2026 18:28
#925198
The coils on my '83 KZ1000 are mounted further forward, on brackets, inside the frame.
It does bring them up from the engine.
The old coil and bracket, very similar in shape as an exhaust muffler hanger.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 22 Jun 2026 18:28 by rstnick.
  • Wookie58
  • Wookie58's Avatar Topic Author
  • Moderator
  • Moderator
23 Jun 2026 01:32
#925208
Thanks Rob, that's how mine used to be but that "real estate" has a sitting tenant now that can't move without a full "re-wire" so it's something of a conundrum !!!!
The following user(s) said Thank You: rstnick
  • MFP-Joe
  • MFP-Joe's Avatar
  • forever 18 when on my bike ...!
23 Jun 2026 05:23
#925210
Could you perhaps rotate the ignition coils 90 degrees from their current longitudinal orientation—using an L-bracket, for instance? That way, the coil's spark plug wire outlets would point outwards instead of sitting so close to the valve cover... just a thought...
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
  • Wookie58
  • Moderator
  • Moderator
23 Jun 2026 06:22
#925215
Thanks Joe, this is the conundrum (I spent most of Saturday scratching my head on the one) the coils aren't round (sides are flat) so if I rotated 90 degrees they would no longer fit between the frame rails so would have to be lower (even closer to the motor) and this would also mean drilling the laminated cores at 90 degrees to the original sleeved hole which I think would compromise the core. Switching to 45 degrees bring the same issue of needing to be lowered but then also the coil mounting bolt and the bracket mounting bolt need to occupy the same space !!!!!
  • MFP-Joe
  • MFP-Joe's Avatar
23 Jun 2026 06:30
#925216
I get it, Guy.
It’s a really tough problem to solve, especially since your setup—including the cables and connections—is all custom-made... keep us posted if you come up with a solution!
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
23 Jun 2026 08:16
#925219
Can you insulate the coils from the engine heat?
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • Wookie58
  • Moderator
  • Moderator
23 Jun 2026 08:18
#925220
Definitely worth looking at Kelly ?
  • moizeau
  • moizeau's Avatar
23 Jun 2026 09:26
#925221
There may not even be an issue. You could stick a thermocouple to the coils to see in realtime what they are having to deal with. My guess would be more heat from tje engine when stationary, parked up after a good run  when the heat rises with no airflow. You  could add 'air tubes'defectors', the Zeph11 has 2 feeding fresh air from the front to the head in the centre. The other thought is, do they have to be mounted in the conventional position. Cars back when Dizzy Caps were a thing had very long HT leads.
  • Wookie58
  • Moderator
  • Moderator
23 Jun 2026 12:50
#925228
To be honest I am fairly set in the “suck it and see” at the moment- my options are limited without ruining the aesthetic I have been working on and the coils looking like an afterthought!!!
  • Wookie58
  • Moderator
  • Moderator
28 Jun 2026 12:22 - 28 Jun 2026 12:25
#925346
 After my last post I have done a lot of "pondering" when the finish line is in sight sometimes it's too easy to say "that will do" when you know it really "won't do". My issue was where to relocate the coils and how to mount them now that everything is painted and powder coated !!! well the solution I came up with was a contraption using a "U" bolt around the centre spar and welding studs into the "L" brackets so that I didn't have two bolts trying to occupy the same space. The "U" bolt is shrink wrapped and the clamping plate has a piece of rubber sheet bonded to it - problem solved :) I have also got the oil lines finished up, exhaust packed and mounted and I've hung the rack to check clearance for the throttle linkage and oil lines - all good so happy with this weekends progress :)
Last edit: 28 Jun 2026 12:25 by Wookie58.
The following user(s) said Thank You: ThatGPzGuy, Nessism, asphalt900, MFP-Joe, sf4t7, Quofan
  • Quofan
  • Quofan's Avatar
28 Jun 2026 15:55
#925349
The coils' solution looks really good mate. Almost there!!
  • MFP-Joe
  • MFP-Joe's Avatar
29 Jun 2026 00:07
#925357
Congrats to your fine solution about the coils,..and all on this bike looks damn good!!!
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
