And finally, Wookie's 82 begins !
Re: And finally, Wookie's 82 begins !
26 Aug 2022 08:00Ok so a quick update, picked my parts up today, no explanation or apology given ! Quote " hello I've got your stuff here in a box" so the shop in question is nkracing.co/ and I would suggest you steer clear unless you are prepared to wait for ever until he's got nothing better to do Don't worry it's not him. I'm not going to call him out publicly as I don't know the full back storyMan that sucks, i used a guy in the uk called.
www.billetbikebits.com/
Hope its not the same guy as i was going to get him to do more work at the end of the year.
- kzstreetfighter71
- Atlantic West Coast
26 Aug 2022 08:19 - 26 Aug 2022 08:20Ok so a quick update, picked my parts up today, no explanation or apology given ! Quote " hello I've got your stuff here in a box" so the shop in question is nkracing.co/ and I would suggest you steer clear unless you are prepared to wait for ever until he's got nothing better to do
Rodger that! though that sucks though mate...
Last edit: 26 Aug 2022 08:20 by kzstreetfighter71.
- Warren3200gt
27 Aug 2022 03:11 - 27 Aug 2022 03:37
Wookie, your in the uk, get Dave Ennis on the job.
Buzzworks.co.uk he's down south in the smoke but is The man on kawasaki top ends and yolk engineering. Z1OC guru.
Last edit: 27 Aug 2022 03:37 by Warren3200gt.
28 Aug 2022 12:48
Still thrashing on that seat pan (it's more my lack of experience with plastics than the size of the job) nearly there now. Was in my comfort zone today bashing metal to make some reinforcers after all the cutting and joining. Really happy with the way it fits to the side panels though
03 Sep 2022 13:30
This seat is turning into the biggest job of the build so far, still should be able to finish up the foam tomorrow and it will be ready to go off to the trimmer. Also finished the frame mounts for it
- calum
03 Sep 2022 14:36
Nice work man. Bet it'll be a good day tomorrow when the bodywork is done!
KZ1000 Restomod (
2000 BMW F650GS
2000 BMW F650GS
03 Sep 2022 16:53Thanks Calum, still got the side panels to rework but shouldn’t be too bad with my newfound plastic skillsNice work man. Bet it'll be a good day tomorrow when the bodywork is done!
04 Sep 2022 11:05 - 04 Sep 2022 11:05
So Seat is done now ready for the trimmer
and I thought I would share some "old skool" trimming techniques for anyone that is interested. You can see from the earlier pics that I had cut and joined the original Triumph foam in a few places, to bind it all together and ensure the joins don't open up at some point in the future I have applied a layer of "scrim linen" wich is like a soft "Hessian" material. This binds the foam and the joint between the foam and the pan. I then added a layer of "scrim foam" which is thin foam on a fabric backing (this is the stuff sewn to the back of covers to create quilting etc) this is like the "high build primer" before your paint job. Hopefully doing all the prep should mean the trimmer doesn't charge the earth as the "donkey work" is already done.
Also dropping off my tree's tomorrow to the guy that made my fork extensions so progressing nicely
Last edit: 04 Sep 2022 11:05 by Wookie58.
The following user(s) said Thank You: Forrest, 750 R1, calum, howardhb
- Forrest
- The Mad Duck
21 Sep 2022 09:31
Thanks for the updates and keep making progress even if it seems minor.
21 Sep 2022 15:59
Thanks Forrest, the seat was my first venture into the world of fabbing plastic so took a while. Still I learned a lot and the side panels are coming along
- Gdailey2112
- 82 KZ1100D1
21 Sep 2022 16:33
what did the rear look like prior to mods? if you posted and i missed it, i do apologize
1982 KZ1100D1
21 Sep 2022 23:56It was a stock 82 Ltdwhat did the rear look like prior to mods? if you posted and i missed it, i do apologize
